Old 12-20-2015, 12:51 PM   #11
L79racer
L79racer's Avatar
Default Re: C2 corvette Stocker question
Originally Posted by jims5600 View Post
L79racer the blue Vette is very nice looking!
Thanks
L79racer is offline   Reply With Quote
Old 12-20-2015, 01:04 PM   #12
L79racer
L79racer's Avatar
Originally Posted by Bobby Zlatkin View Post
I was able to get a 9" X 30" slick under my '80 Vette by just cutting the emergency brake cable tabs off the trailing arms. Was also able to use a 8" wide wheel. No problems after that.
an 80 vette is much easier to get a big tire on. Here is my 80 with a 295 drag radial and a 29x10 slick. Both tires are on an 8.5 rim with a 4 7/8 back space. Once again you need the BFH and some heat at the front of the kick up area of the chassis. Hope these help.
Old 12-20-2015, 01:23 PM   #13
jims5600
Liked 21 Times in 9 Posts
Wow that C3 is very nice too
Jimmy
jims5600 is offline   Reply With Quote
Old 12-20-2015, 03:48 PM   #14
Eman
Liked 133 Times in 76 Posts
Haven't had a Corvette in years. Someone explain the solid axle but still using the cross leaf spring and trailing arms. I'm guessing you use the trailing arms as lower control arms but what else do you need to hold the rear if anything?
Old 12-20-2015, 04:34 PM   #15
Ed Carpenter
Ed Carpenter's Avatar
Liked 520 Times in 132 Posts
Ask Jim Schaector or Tony Hernandez
Ed Carpenter
2005 Chevy Cobalt A/SM
Race Engine Development
Old 12-20-2015, 08:36 PM   #16
Bob Pagano
Bob Pagano's Avatar
Liked 16 Times in 11 Posts
9x30 fits, you need to get dirty, more than one way to do it. Pictures are of Weibe trailing arms witch he dose not make anymore.
ID:	31907   Click image for larger version
Bob Pagano A/SA
Old 12-21-2015, 12:43 PM   #17
Eman
OK, from the pic I see you use a panhard bar at the top for a locator. Years back I destroyed a lot of half shafts and stub axles.
Old 12-21-2015, 11:45 PM   #18
chopperloco
chopperloco's Avatar
Liked 83 Times in 24 Posts
Interesting stuff!
chopperloco is offline   Reply With Quote
Old 12-22-2015, 09:10 AM   #19
rboyle
rboyle's Avatar
Liked 601 Times in 165 Posts
Mid America also sells offset trailing arms and with them and the fiberglass spring I'm able to fit some pretty fat tires under the back of my 1965 Corvette.
Old 12-22-2015, 12:38 PM   #20
bigsixman
Liked 2 Times in 2 Posts
Does anyone have pictures of the Alf Wiebe corvette trailing arm rear suspension system installed in a corvette? I would sure like to see some good close up photos of that complete suspension in a corvette.
Thanks in advance.
1969 camaro, pump gas 540"bbc, jerico
1967 camaro, pump gas efi 620", coan t-400
bigsixman is offline   Reply With Quote
