Old 12-23-2015, 08:51 PM   #11
Billy Nees
Default Re: bracket to stocker
The 305 2V at 180 is a pretty good deal. It's a natural R car that can make T.
I would however think about calling it a 76 and using either one of the 350 Buick motors. The 2V is at 205 and the 4V is at 230.
Billy Nees 1188 STK, SS
Old 12-23-2015, 09:05 PM   #12
Originally Posted by rtaylor3410 View Post
Looks like the 305 is nhra rated at 180hp and would be a natural R/SA
P. Disp. C.R. Ind. Make Model/Transmission Manifold R.R. Lifter Head cc Notes
105 231 9.25 1-2 Roch 17057145,447/SM 1254143 1.53 H 42.70 1,4 Odd Fire
105 231 9.25 1-2 Roch 17057145,447/SM 1257119 1.53 H 42.70 1,7 Even Fire
135 301 9.52 1-2 Roch 7057173,7057172 526213 1.50 H 69.90 3
140 350 9.61 1-2 Roch 7056140,7056143 1249167 1.55 H 50.00 4
145 305 9.24 1-2 Roch 17057107,17057111 346260 1.50 H 59.10 8
155 350 9.61 1-4 Roch 17056246,17056546 1249169 1.55 H 50.00 5
170 350 9.06 1-4 Roch 17057250,3,5,6,8,550,3 411990 1.60 H 66.35 5
170 350 10.21 1-4 Roch 17057202,502 346249 1.50 H 63.35 6
185 403 9.18 1-4 Roch 17057250,2,3,5,6,7,8,550 411990 1.60 H 71.69 5
1 Alt carb - 17057143,148,448/Auto
3 Carb sizes - 1375/1218
4 Carb sizes - 1686/1250
5 Carb sizes - 1375x2250/1218xAV
6 Carb sizes - 1375x2250/1093xAV
7 Carb sizes – 1437/1093
8 Carb sizes – 1686/1186
Bro, You are showing the OP some engines that weren't available in the Skylark.
He's gonna be even more confused.
No 350 4V Chevy till 79. Too high (287) for an entry level deal ..in my opinion.
Old 12-23-2015, 09:29 PM   #13
jmoneyfoot
Liked 9 Times in 5 Posts
Ok thanks for the link. 145hp 305 2bbl
jmoneyfoot is offline   Reply With Quote
Old 12-23-2015, 09:44 PM   #14
jmoneyfoot
can I use any 305 block?
Old 12-23-2015, 10:47 PM   #15
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
I have been told that the block isn't as important as the heads. If the bore, stroke and deck height are correct, casting numbers aren't important.
Dale
Dale Shearon
68 Mustang 6394
Old 12-23-2015, 11:14 PM   #16
jmoneyfoot
Thank you this is all very helpful. I was hoping it came with a 4bbl carb but seems they didnt. Whats a good 2bbl carb that works?
Old 12-24-2015, 02:33 AM   #17
FireSale
FireSale's Avatar
There's no listed replacement for that 2bbl on the NHRA Accepted Replacement Stock and Super Stock Carb List. I think you need to run the stock original for the 305/145.
The 350 had a 4bbl but it never made it into the Skylark or Skyhawk. You could build that engine in the Skylark if you ran Super Stock GT.
Dale
Dale Shearon
68 Mustang 6394
Old 12-24-2015, 08:08 AM   #18
impstocker
impstocker's Avatar
Liked 53 Times in 16 Posts
I understand wanting to build your own car, I am in the process of finishing my 1965 BBC Impala (it is on the Race car build section of forum)
One thing I did was go to NHRA Points Meet, National Event, Stock/Super Stock combo races and just look at other cars and talk to people. I crawled around a bunch of cars.
Not too sure where you live but IHRA has a Stock/GT class where you can run that BBC if it was built into a Stock Eliminator motor, keep tranny and rear end too.
Good Luck and post into the Race car build section.
Will Lamprecht 65 Impala I/SA 396/325
Old 12-24-2015, 01:51 PM   #19
Dale
Been mentioned already...1979
http://www.classracerinfo.com/CGPage...9&MAKE=Skylark
Old 12-25-2015, 02:03 PM   #20
ken robinson
Liked 224 Times in 87 Posts
The 350/170hp 10,20cr. looks like a good combo. same size carb as the 403 motor. In less I'm missing something what class what that fall into ?
