Old 11-28-2007, 01:20 PM   #11
JEFF ESSMANN
Thumbs up Re: Disk Brake rule?
yes they are legal
Jeff Essmann 5780 ss/ja
WEB SITE WITH MY RACECAR
JEFF ESSMANN is offline   Reply With Quote
Old 11-29-2007, 10:20 AM   #12
Greg Hill
Liked 279 Times in 68 Posts
Default Re: Disk Brake rule?
David, my car weighs between 3320 and 3470 depending on the class. Speed is 117-120mph. Hope this helps. Thanks Woody.
Old 11-29-2007, 10:26 AM   #13
David Lee
Liked 346 Times in 126 Posts
Mine will about that weight too, I just wanted to make sure I bout the right setup. The last thing I want is to end up without enough braking power. Did you change the MC and add any proporting vavles etc?
Old 11-29-2007, 11:18 PM   #14
JEFF ESSMANN
on my set up i used a mopar master cylinder its identical to a wilwood and cost1/4of the price. you will have to use a wilwood residual valve on the front and rear brake line use the 2 pound for disc brakes summitt carries them
Old 11-30-2007, 10:01 AM   #15
Greg Hill
David I used the strange 1 1/8 bore master cylinder with no proportioning valve.
