Old 12-25-2015, 11:49 PM   #11
Jeff Stout
Liked 706 Times in 283 Posts
Default Re: TH350 Strength
Originally Posted by Dave Ribeiro View Post
Make sure you talk to Jack Sepanek, he uses a torque strap on most of the T-350 & M-200's ... They are adjustable & work very well .... The other
thing to check into is JW bell-housing, used by lots of Stk / S/S racer's !!!!
Jack, can also help you with those ( JW bell-housings ) Good Luck with your project in 2016...
Any pics of torque strap on m200?
Old 12-26-2015, 12:25 PM   #12
John Nechiporchik
Liked 13 Times in 7 Posts
Send me your e-mail and I'll send you a picture of mine.
My Metric 200 was done by Defiance Transmission in Ohio.
John
John Nechiporchik is offline   Reply With Quote
Old 12-26-2015, 12:41 PM   #13
Liked 1,892 Times in 423 Posts
Originally Posted by impstocker View Post
I am finishing up my 1965 Impala 396/325 Stocker mocking up the motor with TH350 intalled in car. In previous post I mention the tranny has been in storage since 2002, I originally going to use in the 68 Impala I ran. (ran a stick in that one)
The only thing I remember was I did get a 2.75 first gear plus a manual valve body. I don't even remember who built it except I think it was somebody in North Carolina. I finally did drop the pan last week, everything was clean (tranny has never been run) plus has a ATI valve body. I don't know if it has the 36 element sprag, but having it built they knew it was going into a race car, back then I had more $ so for now I can assume it has it. I remember it was around $900 in 2002.
I like doing my own work plus lots of info, in reading Cliff Ruggles "GM Turbo 350" book he says:
"the TH400 case is stronger where it flares up to the bellhousing area. I have seen a good number of TH350 break at this location, but all of those were being used in drag racing with high HP plus traction. Pinion angle, engine mounts (I have solid mounts) and transmission mount play a huge role in case breakage"
He also talks about a solid cast aluminum converter cover w/ strut arms used in some 4X4
1) do other use a solid cover to strengthen, who has them?
2) solid or poly tranny mount?
3) any other issues I am not looking at?
car weight 3900 - 4100 bout 500 HP
Any other info or input would be appreciated. This forum with Billy Nees, Mark Y ect have really helped me with this build, just want to say thanks again. Don't forget, this not a "dime rocket" , more like a "quarter rocket" so I want to stay away from somebody going through it plus a new tranny for now. ( need to get trailer, ect )
Thanks for any help.
Will Lamprecht Div 1 NHRA 65 impala I/SA 2016 debut!
It is most common to use the intermediate sprag from a heavy duty or high performance TH 400. For many years this upgrade has been priced between $400 and $600 alone, on the stock cast drum. It came down to $350 in the last few years. Even at $350, that would be nearly half what you paid to have that unit built. ATI full manual valve bodies for that transmission have been well over $225 for a long time now. The 2.75:1 low gear set has been over $400 for a long time now, as well. So, if you had a completely new transmission built, even assuming you had a very good core that required no hard parts to be replaced, I'd be wondering about that intermediate sprag, among other things, at that price. Especially since you do not even remember who built it. A basic unit with the upgraded sprag, valve body, and low gear set as you describe has been selling for $1500+ on the customer's good core for quite a while.
