Liked 184 Times in 113 Posts
Do these water wetter products work?
Or is it hype? Dan |
Liked 237 Times in 126 Posts
I can't tell you in terms of degrees, but I know how these things work so I'll do that.
I have a degree in Photography from the film days and we used a product called PhotoFlow - a "water wetter" - when developing film. It breaks down the surface tension of water used for the final rinse of film and causes it to sheet off without sticking to the emulsion and leaving spots. In an automotive application it would increase the slick flow of fluid through the engine and prevent it from clinging to surfaces. By not clinging, it should increase it's ability to carry off heat. Disclaimer: I use the stuff. I put zinc additive in my regular oil, too. Dale
Liked 109 Times in 44 Posts
on a couple of my higher compression Buick 455s (years ago) Water Wetter was good for a solid 10 degrees decrease in summer driving temps in SoCal, as seen on a mechanical temp gauge.
Scott McIntyre-Cornville-retirement at last! 2015 Chevy SS. LS3/ 6 spd Stick-Wolf in sheeps clothing! |
Liked 536 Times in 110 Posts
Years ago when I towed with a Ford F250, it helped it to run a little bit cooler while pulling, probably 5-10 degrees.
Jim Kaekel 3836 STK |
#5 | |
Use to work in the Physics Department in College. Took many B&W and Color Photos and Developed them. Sometimes wrote reports detailing findings. Now an art for old school Photographers and Restorers. D |
#6 | |
Dale
Liked 81 Times in 23 Posts
This seems like an unbiased test:
http://www.superstreetonline.com/how...tem-additives/ I know several guys that SCCA race that have nothing but good things to say about it, unless someone blows and engine and it leaks on the track. Apparently, the silicon in it is bad for traction. Who would have guessed? |
Liked 133 Times in 76 Posts
I use the Lucas coolant additive with bottled drinking water. I bracket race so it's a once a year deal. If I was class racing and dropping the water to cool the block I wouldn't bother with anything more than tap water.
#9 | |
Use to do water test and experiments with a centrifuge. FWIW at one time the best tasting water on the East Coast was NYC Water. Big surprise not sure what it is today but usually on top. Chateau de Potomac came close to best tasting tap water in USA. Have seen distilled water being sold. Need to learn where I found it. D |
props for water wetter, have been using it for years in four cars, it works
