Old 01-04-2016, 06:43 PM   #111
grncpe
Liked 44 Times in 10 Posts
Default Re: Horsepowers
That's what I have, I don't have a Holley. I guess I need to build one this winter. My point was about why they are factored the same when there is a difference in cfm. That would be like having a lt1 & l98 factored the same correct? I'm a noob, I'm still learning lol.
Tommy Baker SS/GA # 172
E/SA # 1272
grncpe is offline   Reply With Quote
Old 01-04-2016, 07:02 PM   #112
Sean Cour
Sean Cour's Avatar
Liked 125 Times in 40 Posts
The LT-1 and L-98 are virtually the same hp rating.
LT-1 is 279
L-98 is 270 Dish/flat top 275
Sean Cour
T6066 ladle
Sean Cour is offline   Reply With Quote
Old 01-04-2016, 07:44 PM   #113
grncpe
LT-1 is 279
Ok Sean the lt1 @ 279
L 98 @ 270
9hp
That's 99lbs off of my car at 11.0lbs per hp
Just sayin.
I hope that no one is being offended by this, I am just trying to wrap my head around a virtually the same combo being 99 lbs different. I am just using the 350 combo to make a point about factoring combos. I understand Jim storms deal with a body change, he runs his car out and takes the hit. I guess he should start 1000' racing to protect everyone running that combo and never show the potential. Rant over lol see you next season, I missed Christmas asking Santa Claus to give me some power off.....
E/SA # 1272
Old 01-04-2016, 07:57 PM   #114
Mark Faul
Liked 43 Times in 9 Posts
It gets even more out of whack....
LT1 in Corvette, Camaro or Firebird 279hp
LT1 in GT rear wheel drive 295hp
LT1 in GT front wheel drive 299hp
Mark Faul is offline   Reply With Quote
Old 01-04-2016, 08:03 PM   #115
Ed Wright
Ed Wright's Avatar
Tommy, no offense meant, but why would you put it together with the wrong carb?
Ed Wright 4156 SS/JA
Old 01-04-2016, 08:28 PM   #116
grncpe
I was working on the combo I had. How is it the wrong carb? It has its own combo. I read on here where everyone says to work on your combo more all the time. That's what I did. I got faster, I'm not offended at all Ed , I'm happy with the results I had this year. I know I'm not the fastest, & I'm fine with that. The reason I posted anything on here was my questions about the factoring system of why I am grouped with the Holley & the weight difference in hp compared to similar combos like the Chevy.
E/SA # 1272
Old 01-04-2016, 08:45 PM   #117
Ed Wright
Ed Wright's Avatar
If the two carbs are rated the same HP, you have the AVS, but the Holley flows 100 CFM more, you used the wrong carb. Should have used the Holley. Right?
Old 01-04-2016, 08:56 PM   #118
grncpe
Yup, there is allways next year Ed,
E/SA # 1272
Old 01-04-2016, 09:21 PM   #119
Ed Wright
Ed Wright's Avatar
Should be a big boost.
Old 01-04-2016, 09:30 PM   #120
Doug McCue
Liked 13 Times in 2 Posts
When a combination has so much horsepower added that almost everyone has stopped running that combination, why is nhra so reluctant to reduce said hp?
Doug McCue is offline   Reply With Quote
