#31 |
Liked 71 Times in 23 Posts
It's a BBC rod, but built .500 longer. Not a big deal.
Monte Howard 3209 STK, 3208 SS |
#32 |
Guest
Posts: n/a
[QUOTE=Monte Howard;493093]It's a BBC rod, but built .500 longer. Not a big deal.[/QUOTE
It's only .010 longer.Instead of 6.625 is 6.635 The standard Chev bearing is the same size as a .050 under Pontiac journal. Easy to get bearings, that's the big advantage. The BBC rod is 50 grams heavier as well. No great injustice here so relax. |
#33 | |
Liked 18 Times in 10 Posts
Back in 68 no one was using MM ring packs like what are available today. Mahle now offers a 1MM 1MM 2MM ring pack and Mahle rings from what I have seen seal up good on start up. To achieve good ring seal plate honing is a must which was not used way back when. A good hone is a must with the proper abrasives. No matter what you use for a ring its not going to seal if the cylinders are not round once the head is bolted on or the proper finish is not used for the final honing. Richard Maskins has a good view on honing. https://video.search.yahoo.com/video...t=mozilla&tt=b Here are some pics of cylinders that were not plate honed and I don't care who's ring are used in these engine that are not going to seal. Look at the blowby under the top rings. ![]() ![]() ![]() Shadows under every bolt hole when the torque plate bolted on. ![]() |
#34 |
Liked 535 Times in 110 Posts
[QUOTE=Dwight Southerland;493003]If you can change your mindset to be satisfied with "competitive" not "ET killer", that is the first step to having the inspiration to do your own engine work. After a few serious builds and intense striving for information and skill, it is amazing how much you understand. You then have a reference base of knowledge that helps you to glean more information from everything you read, even advertisements.
That is outstanding advice for anyone that doesn't have a "bottomless pit for a budget".
Jim Kaekel 3836 STK |
#35 | |
Liked 1,892 Times in 423 Posts
[quote=Todd Hoven;493117]
Todd, pretty sure he meant it is 0.500" longer than the stock big block Chevy rod, which is 6.135" long. The FE Ford was also allowed to use an aftermarket big block Chevy connecting rod before the aftermarket made rods specifically for them. On the original subject, these days most of us try to get our piston company representative together with our ring company representative, and make sure the ring grooves and rings are well matched. I've found that my friends at JE and CP have no problems talking to Keith at Total Seal, and making my pistons match my rings really well. I do not do much to my rings or ring grooves when I get my parts.
Alan Roehrich 212A G/S |
#36 |
Liked 1,946 Times in 587 Posts
Alan
Who do you talk to at JE. I need to get 2 pistons to replace 2 that were damaged Thanks,
Mike Pearson 2485 SS |
#37 | |
Liked 320 Times in 102 Posts
It doesn't go in the oil!!!!!!!!!!!!!!!!!!!!! Remove the spark plugs and put the BonAmi directly into the cylinders and crank her over....Use air to blow out whatever you can from the cylinders.....Start it up....Let it run for a bit....Change oil and filter...See what you got....Sometimes better...Sometimes not...It's just a bandaid.. GM also had TSB's about helping ring seal and oil consumption by using GM Top Engine Cleaner in Gas & Diesels.....Gas it went down the carb and diesels it went in thru the glow plug holes... Just a crutch... Bob
#38 |
Liked 404 Times in 158 Posts
We called this "flinting" an engine when we did it to 6v53detroits. They would idle so long they would gum up and when you stepped on it there was a cloud you could see for a mile plus it had no power for a while. Once it got real bad we'd pull the air filter and at a fast idle throw a handful of scouring powder in. Couple rev's and see how much it smoked, maybe do it again.
Worse case scenario, we sent the engine to second line for rebuild. |
#39 |
Liked 10,837 Times in 2,252 Posts
The NHRA approved rod list for the Pontiac 350, 389, 400,421,428, 455, it looks like all the OEM rods were the same size. 13 rods are listed on the approved list with only two rods as super stock only. Of the remaining 11 rods, nine are listed as the OEM size. Crower makes two, Oliver has three, Eagle has one, Childs and Albert has one, and Carrillo makes two.
It looks to me a lot of venders make a rod for that engine. It ok to grind the crank .049'' under (NHRA allows -.070'') to 2.200'' crank pin size but nobody makes a rod bearing -.049'' under that fits into a 2.375'' housing bore. If I read the rules correctly spacers are not allowed in stock. So if good bearings are not available just ask NHRA for a new rod, AKA the FE ford rule. |
#40 |
Liked 72 Times in 27 Posts
Mopar ask for the same thing for the dragpaks. At least the Pontiac uses a corporate bearing size.
So if good bearings are not available just ask NHRA for a new rod, AKA the FE ford rule.[/QUOTE] |
