#41 |
Liked 408 Times in 35 Posts
I had this tool made up about 25 years ago. It is for a 4.060 bore. On one side there is a dish cut in it that allows you to hold a ring inside of it. The ridge is about .025 tall so that the ring is exposed. I can then use this fixture to sand down the ring on a piece of fine paper taped to a piece of glass. The other side of this ring fixture is used for squaring rings in bores when checking / setting the ring end gaps.
George Wright https://9500rpm.com |
#42 |
There is now a new guy at JE running the Stock and Super Stock program, his name is Allen. I have not dealt with him as of yet, but plan to talk to him in the next 2-3 weeks.
Alan Roehrich 212A G/S |
#43 |
Liked 10,943 Times in 2,259 Posts
George when you put a taper face ring into the fixture does it want to cup the ring up, away from the land when in compression?
Thanks Larry |
#44 |
Liked 880 Times in 311 Posts
This is how a friend of mine back cuts rings to decrease tension.
Adger Smith (Former SS) |
#45 | |
And, no the rings stayed in place just fine. Lap one side flat, flip them over and lap the other side flat. Mic the ring, and if needed, touch up the thickness.
Ed Wright 4156 SS/JA |
#46 |
I was not using tapered rings.
#47 |
Larry, the top rings I have used were all barrel faced. Had tapered second rings. Never lapped those.
#48 |
Liked 370 Times in 101 Posts
Jerry Heath I/S '93 Cobra FS/J 2010 Mustang "Ebay CJ" |
#49 |
Liked 22 Times in 14 Posts
Thanks Jerry!
Rick Thomason GTOMayhem |
#50 |
Liked 5 Times in 3 Posts
Ok fellas ,I'm a dummy ,I just read a lot trying to understand. If you actually increase the thickness of the rings doesn't that allow compression to leak behind them.? Thanks
Joe Keightley Pacific Junction Iowa |
