Old 01-26-2016, 09:25 PM   #51
Pvt Parts
Pvt Parts's Avatar
Default Re: Lapping piston rings
Originally Posted by Bob Mulry View Post
Just a quickee................
It doesn't go in the oil!!!!!!!!!!!!!!!!!!!!!
Remove the spark plugs and put the BonAmi directly into the cylinders and crank her over....Use air to blow out whatever you can from the cylinders.....Start it up....Let it run for a bit....Change oil and filter...See what you got....Sometimes better...Sometimes not...It's just a bandaid..
GM also had TSB's about helping ring seal and oil consumption by using GM Top Engine Cleaner in Gas & Diesels.....Gas it went down the carb and diesels it went in thru the glow plug holes...
Just a crutch...
Bob
GM's Top Engine Cleaner was used primarily to decarbon pistons and combustion chambers. Have you ever used it or seen someone else use it. Oh my!!!! I used it many times when I worked at Chevrolet Dealers in the 1970's, mostly to eliminate "carbon knock" when carbon build up was great enough to create contact between the piston and the head.
Here's the process: Bring engine up to operating temp. Open throttle to 3000 to 4000 rpms. Pour the TEC down the carb to reduce rpms to around 2000. By now the smoke is rolling like the building is on fire. Pour the last 1/3 to 1/4 of the can in quickly in order to stall the engine. Let the engine cool 30 to 60 minutes. Fire it up and take it out for a very aggressive test drive.
Most of the time it fixed the carbon knock issue. However, I did see one tech pour the last part in too fast and it bent a rod. Not surprising. I'd be very surprised if it is still in use today. The EPA would have a hay day with the emissions, not to mention damaging the cats.
Old 01-26-2016, 11:15 PM   #52
Ed Wright
Ed Wright's Avatar
I made the mistake of using that stuff ONE time inside my shop. And, the tail pipes turned down. Black spots on the floor, and could hardly see. That is an outside operation, imho. :-)
Ed Wright 4156 SS/JA
Old 01-27-2016, 01:20 AM   #53
Pvt Parts
Pvt Parts's Avatar
We always had the rear end just outside the bay door when we used it. Some guys claimed that ATF worked just well but I never used it.
Old 01-27-2016, 08:52 AM   #54
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
In my early days of turning wrenches I worked with an old(er) drag racer who used ATF down the carb to eliminate carbon knock. It always seemed to do the trick, but it had the same characteristics as you related about TEC. We had the local fire department show up once . . .
Old 01-27-2016, 09:32 AM   #55
Rich Biebel
Rich Biebel's Avatar
Liked 557 Times in 217 Posts
Onan made a product to carbon clean engines. 4C cleaner, and you sprayed it in the carb of a running engine. Similar smell as the GM cleaner and some other products you could buy. Bluish white smoke poured out the engine. It did help but definitely not as effective as removing the heads and carbon cleaning the engine.
An Older Onan flathead engine can literally stop turning over from the carbon buidup. Took a machine out of a support vehicle at the World Trade Center site after 9/11 that did.
We put in a new generator but the old one was just locked up from carbon on top of the pistons.....No time to waste there....
The stuff was easily the best carb cleaner as it dissolved pretty much anything in carb passages.
None of these products are still available and I tried to hunt down a case of 4C a while ago.....None available and no longer made.
Tried a lot of other chemicals....Mopar made a carbon cleaner too but I don't think they sell it anymore either....
SeaFoam works but nowhere near as well.....
Rich Biebel
S/C 1479
Stock 147R
Old 01-27-2016, 02:07 PM   #56
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
Hi,
I worked at a Cadillac Dealership and had to work on the HT4100 engines. The tune up guys would send the cars to heavy duty to have the trans diagnosed for no full throttle upshift. We would run a can of TEC through the engine to remove the varnish from the valve stems to prevent them from sticking. Re-road test and the trans was fixed.
The varnish caused the engine RPM to flatten out and not reach the RPM needed by the governor to do a full throttle upshift.
We pulled out a lot hair on that one.
Bob
Bob Mulry 7516 STK
A & M Motorsports
Old 01-27-2016, 02:09 PM   #57
Ed Wright
Ed Wright's Avatar
Hi,
Bob
Interesting!
Old 01-27-2016, 03:17 PM   #58
Rich Biebel
I can definitely identify with the difficult diagnosis issues from my days as a dealer mechanic.......Mid 1970's Pontiac-Jeep-Subaru line mechanic....flat rater
GM was producing some really poor stuff and the Jeeps and Subarus new to this country had more than their share of problems....
Rich Biebel
S/C 1479
Stock 147R
Old 01-27-2016, 08:20 PM   #59
Bob Mulry
Bob Mulry's Avatar
You got it right...............
440-T-4, 700-R-4, 200-4-R, 200C some them so bad that the factory said when you get it figured out call us and we will put out TSB's....
They built them and early in the production runs we had to figure out how to fix all of the drivability problems......
As time went on the factory got a handle on them and had updates for the problems...
I worked at several dealerships Chevy, Pontiac, Olds, GMC & Cadillac but no Buick dealerships and we raced one of those also............
Bob
Bob Mulry 7516 STK
A & M Motorsports
Old 01-27-2016, 08:55 PM   #60
Rich Biebel
The Bon Ami deal was only something I heard about but did not remember how it was actually used. My apology for giving bad info there. 50 years ago is hard to remember. Makes more sense in the top of the engine and not in the oil. The stuff is abrasive and Pontiacs don't need any help with spinning bearings ....lol Total Seal sells a powder to use on your cylinder walls to help seat rings. I have used it. Maybe they heard about Bon Ami....!
Rich Biebel
S/C 1479
Stock 147R
