Old 02-01-2016, 01:14 AM   #1
J Slane
Default Valve springs
I have pac Springs on my O 41 heads, spring pressures run between 270 and 310. I have lots of room, no shim under the springs. When they were new, spring pressure 350lbs. I have enough room to run a 60 shim and will not coil bind. Would a 60 make much of a difference in pressure. Any suggestions Thanks Jay. GT\DA
J Slane is online now   Reply With Quote
Old 02-01-2016, 09:57 AM   #2
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 308 Times in 103 Posts
Default Re: Valve springs
yes that will raise pressure,maybe time for a new set though install them to where they are .060'' from coil bind if they are 1409X will be about 425-450 like that.
Mike Taylor 3601
Old 02-01-2016, 08:02 PM   #3
Mike Pearson
Mike Pearson's Avatar
Liked 1,948 Times in 589 Posts
Mike Taylor 3601
They are the PAC 1.500 double spring that sets up at 2.100. They are pretty old but trying to get a few more runs before a new set.
Mike Pearson 2485 SS
Old 02-01-2016, 08:08 PM   #4
Mike Pearson
They are the Pac 1332 spring. Any one know the rate on these springs.
Old 02-01-2016, 09:42 PM   #5
james schaechter
I think everything you need is in the PAC web site
http://www.racingsprings.com/ValveSpringRateCalculator
James Schaechter 3163 STK
Old 02-02-2016, 02:53 PM   #6
Mike Pearson
Thanks James. That's a nice tool. I never noticed that before on their website.
