#11 |
Liked 24 Times in 13 Posts
Does this mean that if you have 4 grade points and enter a national event that required 4 points to enter, all your points are gone?
Terry K |
#12 |
Liked 325 Times in 50 Posts
Terry, I think it might be like letting your motor cool off after making a run. I am going to try again when it gets to 110 Degrees. Jennifer might be the way to go.
Jeff Teuton 4022 STK |
#13 |
Liked 431 Times in 224 Posts
Yes, but only for that event. You will have 4 grade points to 'use' for entering each event.
S/ST 51 S/C 53 |
#14 |
I believe once you withdraw from a class you can not re-enter.
Lane Weber It`s Not What You Drive That Wins....It`s How You Drive It |
#15 |
Liked 2,639 Times in 441 Posts
I believe that you are correct.
Bill Seabrooks - superfan1 Bridgeport, CT |
#16 |
Liked 60 Times in 12 Posts
Mr Jeff, my comment wasn't meant in an ill way, simply I was simply surprised, with as much as you and your guys have raced, div and nat'l events, that you were having the difficulty. I hope it wasn't taken that way.
2894 STK |
#17 |
I was hoping to get in. Guess I will have to wait til next year.
#18 |
Only 3 spots left
#19 |
Liked 13 Times in 3 Posts
Unless it has changed, that is not true. I have entered an event using combined points for a class to then realize I couldn't enter the other class. Withdraw out of the first class, enter the second class and then re enter the first class.
Chuck |
#20 |
A change was made a couple of years ago, if they still abide by it, who knows?
