Old 02-03-2016, 08:54 PM   #1
Kenny Wigington
Kenny Wigington's Avatar
Liked 60 Times in 12 Posts
Default SS/GT question
Is there a place, in GT categories, where you could run a newer , late model FI engine, in say, for instance, an 84 Cutlass ? Just wunderin'
2894 STK
Old 02-03-2016, 09:13 PM   #2
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
Default Re: SS/GT question
The factory hot rod motors - CJ, COPO, DragPak - are restricted to 08 or later bodies. Other than that I think "any engine same make as body, year optional" means just that. I've seen 55 Chevy's in GT with late model LS motors. At least on TV broadcasts of NHRA events.
Dale
Dale Shearon
68 Mustang 6394
Old 02-04-2016, 10:56 AM   #3
Mike Pearson
Mike Pearson's Avatar
Liked 1,964 Times in 595 Posts
Kenny
You can put any corporate engine you want in your car and run GT. You can run an earlier or later model engine as long as it is in the guide.
Mike Pearson 2485 SS
Mike Pearson is online now   Reply With Quote
Old 02-04-2016, 11:24 AM   #4
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
Kenny
No truck engines. And if you use one of the 2008 up factory hot rod engines, you will run FSGT classes.
Old 02-04-2016, 01:11 PM   #5
Randall Klein
Liked 316 Times in 67 Posts
Question: with all these alphabet soup classes, how do they handle class runoffs with single cars nowadays?
Old 02-04-2016, 02:57 PM   #6
ALMACK
ALMACK's Avatar
Liked 372 Times in 130 Posts
On the flip side....
Anyone ever hear of a SS/GT racer using a '08-'16 Factory Stock body (or clone of one) and using a 2007 and older engine ?
P/SA & SS/PA Fox Thunderbird
I/PS '95 Mustang GT
Old 02-05-2016, 10:21 AM   #7
Kenny Wigington
Thanks All !
2894 STK
Old 02-08-2016, 12:16 AM   #8
Stewart Way
Liked 70 Times in 22 Posts
OK Kenny
I know that is not a random question. Spill the beans. What's the plan?
Stewart Way 2424 SS
Old 02-08-2016, 09:43 AM   #9
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
It might be hard to put one of those FS engines in an older car, without a big change to the intake manifold .
Old 02-08-2016, 04:59 PM   #10
Jeff Teuton
Liked 325 Times in 50 Posts
New body (08 up) with matching motor FSS/something. New Body old motor FGT/something. New motor old body FGT/something New body/new motor/different years FGT/something. Smaller the motor, the more screwin you get because there is no stick/auto in the FSS and FGT arena and NHRA used the stick factor and in the lower FSS and FGT classes, the difference is as much as .25 and that's a lot. If you goin that way, use the new high horsepower stuff. Using an old motor in a new car probably won't work well. This applies to DP, Copo and CJ bodies/engines. Showroom stuff is SS and GT.
Jeff Teuton 4022 STK
