Old 02-05-2016, 04:07 PM   #11
Rod Greene
Liked 242 Times in 81 Posts
Default Re: 8 3/4 Center Section
If you go with the S60 center section for your dana, it is very easy to have extra gear sets set up and ready to go. They can be changed almost as fast as 9" or 8 3/4. Molly tubes and 40 spline rifle drilled axles make the dana even lighter and totally bullet proof.
Rod Greene Real men shift for them selves. Slowly working on TA Challenger for D,E/S and a 72 Challenger for SS/K, L as if I don't have enough other projects.
Rod Greene is offline   Reply With Quote
Old 02-07-2016, 12:08 PM   #12
bill dedman
Liked 6 Times in 4 Posts
Can anyone tell me how the Mopar 8.25" unit stacks up against the drop-out 8.75" in terms of efficencty and weight? I know that a lot of small-bloch Dodge anbd Plymouth racers have replaced the 8.75" rears with these lighter Chrysler Spicer types in the past, but I am wondering about total weight, aftermarket axle availability and strength.
This would be for my 2,700-pound, turbocharged slant-six powered, 904 equipped, bracket car.
Any information would be much appreciated. Thanks in advance...
Bill
bill dedman is offline   Reply With Quote
Old 02-07-2016, 03:03 PM   #13
Rsmith38
Liked 28 Times in 15 Posts
Can't help on the 8 1/4 but the DANA 44 is supposedly as efficient as the Dana 60. Moser makes aftermarket axles, spools and gears are available. 4 89 5.13 5.38 5.89 that I know of. I have a Summ ers Bros spool available.
Rsmith38 is offline   Reply With Quote
Old 02-08-2016, 11:31 AM   #14
Rod Greene
Hey Bill, we have a brand new 8 1/4 Strange spool and 5.38 gears. Would let them go cheap.
Old 02-17-2016, 11:01 PM   #15
GTX JOHN
Liked 2,518 Times in 702 Posts
Bill: The 8 1/4 lasted several years in our 11/12 Second stockers in the
70s. They are lighter and a bit faster. Gear supplies dried up in the
80's with the deepest gear available 4.50. and no 4.80 to be found anywhere.
The slant 6 should be fine unless you re using transbrake and 7 inch convertor.
John Irving
741 Stock
741 Super Stock
Old 02-17-2016, 11:16 PM   #16
Rick Blake
Rick Blake's Avatar
CK Here for 4.88 ... not sure how well the Brand is...???
http://www.summitracing.com/parts/spz-36268/overview/
Rick Blake 2395 SG, SC, SP
Rick Blake is offline   Reply With Quote
Old 02-18-2016, 01:19 AM   #17
GTX JOHN
Last time I ran one was early 1980's. Only gears then were from Mopar
Perf. that I could find. My 1980 Dodge Mirada O/SA is still running a
8 1/4 to this day in stock competitively on East Coast.
I do not know of anyone else in stock although there may be others. The Mirida runs mid 12s at 3620 lbs. and has the same ring and pinion for at least 30 years and three owners.
Larry Shephard told me back when these cars were new when Chrysler changed
from 8 3/4 to 8 1/4....they saved about a dollar a unit!
John Irving
741 Stock
741 Super Stock
Old 02-18-2016, 08:11 AM   #18
topless63
Randy's Ring & Pinion. the new Yokon case is very good
topless63 is offline   Reply With Quote
Old 02-18-2016, 09:03 PM   #19
340Cuda
Liked 823 Times in 342 Posts
I am one of many that has swapped a 8 3/4 for a Dana, not done anything else and not slowed down a bit.
Bill
Old 02-20-2016, 07:35 PM   #20
Chris DeGidio
Chris DeGidio's Avatar
Liked 2 Times in 2 Posts
Bill
Same here in 2 different cars. Dana 60 is one less thing to worry about.
Nautilus Racing
Chris DeGidio is offline   Reply With Quote
