Old 02-13-2016, 12:21 PM   #11
Eric Merryfield
Eric Merryfield's Avatar
Liked 502 Times in 130 Posts
Smile Re: New to Stock eliminator
Originally Posted by Racer 6x64 View Post
the tag under the hood is a 2015013. So now just to get the rest figured out. The paperwork we have for the car recommends c25 fuel?? I am not exactly sure that is legal in Stock. This is defiantly going to be interesting. But for the weight and what all of you mentioned I am guessing it will be a C car. Sorry for asking so many questions but stock class is anything but stock. Thanks for all your input.
Curtis
Here is your class info from the awesome classracerinfo site.....looks like you can run A-C, and then C-E in super stock, you should register for Dwight's site pronto.
RE C-25, with just under 15 compression ratio up to 16.5 or so you certainly will be running the liquid gold. Its not cheap 25 bucks or so per gallon, buy it in the 5 gallon pails and stockpile. As you will not be able to get VP as easily as in the past and certainly not at national events. But you didn't buy a dragpak to try and economize now did you! Have fun, you will find a lot of help on this site. If you are coming from T/S, everything is likely cheap in comparison!
2015 Dodge Challenger Coupe 2 Dr Drag Pak with 460 HP 426 Cu In Engine
Shipping Weight: 3200 lbs Wheelbase: 115.5"
Stock Classes HPFactor: 460 Power/Weight Factor: 6.96
Stock Classes Class Min Wgt Over/Under Shipping Wgt Min Wgt w/Driver 1/4 Mile Man Index 1/4 Mile Auto Index 1/8 Mile Man Index 1/8 Mile Auto Index
Lightened Class FS/A - 6.00 Lb/HP 2760 -440 2930 9.70 9.70 6.32 6.32
Natural Class FS/B - 6.50 Lb/HP 2990 -210 3160 10.00 10.00 6.50
6.50
Weighted Class FS/C - 7.00 Lb/HP 3220 20 3390 10.30 10.30 6.68 6.68
Manual and Auto run together.
Super Stock Classes HPFactor: 460 Power/Weight Factor: 6.96
Super Stock Classes Class Min Wgt Over/Under Shipping Wgt Min Wgt w/Driver 1/4 Mile Man Index 1/4 Mile Auto Index 1/8 Mile Man Index 1/8 Mile Auto Index
Lightened Classes FSS/C - 6.00 Lb/HP 2760 -440 2930 9.65 9.65 6.28 6.28
Natural Classes FSS/D - 6.50 Lb/HP 2990 -210 3160 9.90 9.90 6.44 6.44
Weighted Classes FSS/E - 7.00 Lb/HP 3220 20 3390 10.05 10.05 6.53 6.53
Eric Merryfield 1883 STK
