Liked 166 Times in 71 Posts
To get the 624 sbc head down to the neighborhood of legal (63.3 minimum) I assume they are being angle milled? Can anyone confirm this and if so what how far are you rolling them?
Chris Chapman 1969 Chevelle NHRA F-G/SA 1090 |
Liked 308 Times in 103 Posts
taking 882's down to 64cc we angle milled .150''
have cut 614's which are light weight casting like the 624 that much also. 624 and 882 style casting can angle mill like that without water jacket on spark plug side giving you a problem,I.E. older castings like 461,462,291 style you had to plug small water jackets by spark plug because gasket wouldn't cover them any longer. If don't have one, make a square(that won't be square) that matches intake to head surface angle,so when set up to correct intake face of head you can setup from the square from head surface so you can mill intake face back at correct angle. Mike Taylor 3601 |
Tried .150" and it took our dummy head from 76.5 to 57cc. We'll try a little less on another lol.
#4 | |
I think the 882's may have started off 78-79 cc been a while. Mike Taylor 3601 |
Liked 66 Times in 37 Posts
Did you stop at the end rails or did you go the entire head?
72 cutlass |
I setup to mill the whole head,when setting up check with dial indicator so there is the amount of angle you want, I.E. zero at exhaust side and .125'' at intake side of end rail,that should be right at .125'' angle mill, if still use stones on mill then it will take more than that by the handwheel because stone loss,but it should be .125'' removed from head although handwheel will show more.
You can mill and leave end rails uncut and seal with silicone,but I always try to mill whole head less chance for leaks. Mike Taylor 3601 |
#7 | |
Liked 327 Times in 121 Posts
Liked 544 Times in 213 Posts
Beyond the deck area of the head up to the intake. A short section that just seals the head to the block at the valley area.
If your angle milling a lot you don't have to keep milling to finish that area and make the head perfectly flat.... The last couple passes will cut that flat... I always did .... I ran an 85-B for years and angle milled plenty of heads.... Big Block Chevy heads....for SS use.....LS-6 Small Block Chevy heads for various uses.... I angle milled a set of 462 heads for an engine I ran down to low 50's CC's Flat top pistons....383...13-1 compression...
Rich Biebel S/C 1479 Stock 147R Last edited by Rich Biebel; 03-05-2016 at 11:10 AM. |
Liked 68 Times in 31 Posts
Call Matt Steen @ Victory Engines they have
done quite a few of those 624 castings!
Ron Mattson 5015 STK Last edited by ron mattson; 03-05-2016 at 03:34 PM. Reason: Spelling error |
#10 | |
| Thread Tools | |
| Display Modes | |
