#11 |
Ron, from what I saw with the local circle track cars, I would say you are mistaken. I posted what I observed. More power required to run the big pump is the only thing I know of that would wear gears like that. Old as I am, I haven't seen everything yet.
From your description of the oil pressure you are seeing, I would say you problems other than the pumps. I just put a new Moroso std volume pump in my spare engine, which I recently sold. Oil pressure was solid at 60 psi all the time. Hot or cold (5W20) idle or WOT. You have something wrong somewhere. I have an old rear main cap, with a gauge on it. I bolt my pumps on it, drop it in my parts washer, and spin it with a 1/2" drill to see where the relief valve is set. Whatever it shows there, is what it shows in the car. My thinking is solvent, being thin, would be similar to hot, thin weight oil. I noticed solvent spraying out from the area where the pump mounts. The machine marks was the culprit. Also, some do it where the end plate mates to the main housing. I have a surface ground plate I use with wet-or-dry sand paper in the parts washer for sanding piston tops to correct the deck. I started lapping the oil pump mount, end of the housing, end plate, and pull the dowel pins from the rear main cap. I lap all the machine marks from those four surfaces. Stopped the leakage. I prefer my oil going into the oil galley. I don't see how excessive leakage those two places could help anything. Some machine marks are worse than others. Hope this gives somebody something to look at.
Ed Wright 4156 SS/JA |
#12 |
Liked 880 Times in 311 Posts
Ron,
You seem to have a good grasp of what is going on and you are close on the cause of pressure. (sorry this gets long) Look at the way it works with your garden hose. Yea, one of those cheap soft plastic garden hoses. You have it hooked up to your house/city water supply. Open the valve wide open at the house end. You are now flowing the set volume (through the valve as a flow orifice) Behind that valve/orifice you have a pressure, say X. Then on the hose side of the orifice/valve you take a pressure reading and find out it is X minus. (lower on that side) Your end of the hose is wide open and there is nothing on it to slow the flow, Volume. You screw on one of these twisty spray nozzles and the pressure on the hose goes up (the soft plastic also swells) because you have cut the volume of the free flow. As you cut back on the volume to an orifice the same size as the house valve the pressure on the hose side is less than the house side of the valve. When the volume of the spray nozzle equals the volume of the house valve the pressures on the hose and house will be equal, too. How much pressure and volume will it be? That all depends on the source. How much capacity the source has and if there is a bypass in the system. Now we are at the oil pump. You said"Pressure is determined by excess volume and the bypass spring" Yes and No. For all practical purposes you can turn any automotive pump in a free flow situation and utilize 100% of it's volume and have 0 pressure and not have any bypass activity. Now put tight bearing clearances and tight lifter bore clearances on the end of that free flowing pump. AHA! you have pressure, resistance to flow volume. Vary the clearances and you vary the "Require flow volume" which will limit the volume out of the pump and increase the pressure till it kicks the bypass in the pump open. The excess volume then bypasses and the output is held at what the bypass regulates the pressure and volume to. Start by determining what your required flow volume is. Do you have tight or loose clearances? Then figure out what pressure you want or need. Don't pump any more oil at any higher pressure than you absolutely need. It will take more power if you go up on either one. It may not be 5 to 7 HP, but it is power. The way I first started approaching what was required was to consider what the engineers designed for the original engine. They are going to over engineer whatever they do by a certain percentage. If you have reasonable clearances the flow demand will probably match the flow capacity of a stock pump. Keep in mind the flow capacity of the pump varies with RPM. Ever wondered why the pressure drops when you slow the rpm down? The pump flow capacity gets less and the flow required by the engine clearances stays the same so there is not enough excess volume to work the bypass. The trick is to get the least amount of loaded pump to flow the required oil volume at a low pressure to keep the bypass from over working. 1. Why is a Hi vol pump needed. "Market Demand" The avg person has no idea what is going on, but they don't want the pressure to drop when the engine speed slows down. 2. Hi Vol might be needed in some extreme cases of clearance or "Required Flow" 3. The end user usually equates engine health with hi oil pressure.(it Ain't so) Now to the anti cavitation. It is my opinion that when you have too much pump gear size and are working the bypass too much the gears will cavitate. They will build real high pressures on the outside of the gear teeth and the low pressure on the inside causes air bubbles. The cavitation slots in pumps are there to reintroduce higher pressure oil to the low pressure areas. I think it is a crutch. If you have a pump that is matched to your system needs you don't need them. Again the customer doesn't know or understand why the pressure drops when you are at idle. So they do cause problems of misunderstanding with customers. At this point I might add I don't like a system that is over pressured or has too much volume. It can get you into trouble with oil aeration. Air in oil doesn't lubricate or cool the parts & air can negate some of the effects of chemicals that are in the oil. If you experiment with your pump system and run only what you need you can save a little power. (Each engine and combination has it's own requirements)
Adger Smith (Former SS) Last edited by Adger Smith; 03-06-2016 at 07:20 PM. Reason: SP |
#13 | |
Liked 7 Times in 6 Posts
#14 | |
#15 | |
The dowel pins do go back in. Never used glass. May be fine. I used 280 grit paper, then 400. I think you have something screwy going on to have oil pressure like you discribed. I've never had one do that.
Ed Wright 4156 SS/JA Last edited by Ed Wright; 03-06-2016 at 10:11 PM. |
#16 |
Liked 1,945 Times in 586 Posts
I have found over the years that you are much better off using a product that is specifically designed for a racing application instead of using a modified passenger car type product. I found this out the hard way. I use a Moroso billet oil pump a system one oil filter and racing quality engine oil just to name a few. Just Google Meling oil pump failures and you can get some info. The pump that broke was a Melling M55. Snapped off at the neck just below the bolt flange. It destroyed that short block.
Mike Pearson 2485 SS |
#17 |
Liked 783 Times in 195 Posts
You need to look at the block carefully. You could have an internal crack in an oil gallery that expands with heat. I have seen that on two big blocks that exhibited similar characteristics. It can make you crazy chasing pumps, pickups to solve the problem.
#18 | |
[IMG] ![]() |
#19 | |
#20 | |
I am not a professional engine builder. I just cobble my own crap together, and have helpped a couple of other guys in the past. Someone like Adger differs, I defer to them.
