Old 03-07-2016, 10:19 PM   #1
Doug Domm
Liked 84 Times in 21 Posts
Default Turbo 350 shift kit suggestions
I'm looking for suggestions on shift improver kits for a turbo 350. This is not a race car so not interested in a full manual and teeth rattling shifts on part throttle shifting but firm to hard shifts at full throttle would be the ticket. Thanks Doug
Doug Domm is offline   Reply With Quote
Old 03-07-2016, 11:05 PM   #2
Mark Ugrich
Liked 71 Times in 38 Posts
Default Re: Turbo 350 shift kit suggestions
I've used both B&M and TransGo at different times.Either one seemed to work equally well.If you don't want neck snapping shifts,leave the 1-2 accumulator spring in place or replace it with one from the kit.
Old 03-08-2016, 12:44 AM   #3
Superior, or Fairbanks. Been using them for 30 years.
Old 03-08-2016, 07:05 AM   #4
Lou Jeffery
I would also recommend the Trans go shift kit. The instructions are well written and it is easy to install. The kit also has different stages to taylor to your needs. You can buy on Ebay or any transmission parts distributor.
Lou Jeffery is offline   Reply With Quote
Old 03-08-2016, 10:10 PM   #5
Eman
Liked 133 Times in 76 Posts
Transgo hands down. I've used B&M and Transgo and the Transgo is better. It doesn't slam into reverse or shift gears hard. B&M is much more aggressive.
Eman is online now   Reply With Quote
Old 03-09-2016, 12:05 AM   #6
Chipper Chapman
Chipper Chapman's Avatar
Liked 166 Times in 71 Posts
Transgo, no other way to do it right.
Chris Chapman
1969 Chevelle
NHRA F-G/SA 1090
Old 03-09-2016, 01:43 AM   #7
Greenlight
Liked 79 Times in 22 Posts
Just drill the valve body spacer plate as shown in the image about 3/4 the way down the page in the link shown below.
http://www.crankshaftcoalition.com/w...0_rebuild_tech
Greenlight is offline   Reply With Quote
