Old 09-28-2015, 10:43 AM   #51
joe huestis
Liked 409 Times in 113 Posts
Thumbs up Re: New website: "What class does this run?"
Thanks for pointing that out, Joe! Corrected it this morning along with the full size body.
How are you doing with the 305 180?
Had an accident back on Aug.30 falling from a tree I was cutting down. Fractured my pelvis in 2 places and fractured my rt. hip requiring surgery. So, have not not been able to work on the Camaro much since. Car is back from body shop with fresh paint ( victory red) and converted to manual steering. Next I will tackle converting to manual brakes and install line-loc. Process will be slow but I am chomping at the bit to get it finished. Have accumulated several parts and plan on this being a nice build once complete. I believe the 305/180 will be a viable combo for R/T/U stock and looking forward to having some fun with it. Thanks for asking ! - JOE
Joe Huestis
Youngsville, NC
Old 09-28-2015, 11:33 AM   #52
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
Default Re: New website: "What class does this run?"
Gosh! I am so sorry to hear! I hope you have a full recovery, and soon!
But I am glad you are continuing with the build. I too think there is lots of potential in the 305-180 combination. Good luck and keep me posted with the progress!
Old 12-29-2015, 09:17 AM   #53
Dwight Southerland
I am working diligently to get all the hp changes in the CRI database. I will make a big announcement when the project is finished. There are also some programming changes going in that will address some of the problems with the Mopars and Fords that have multiple ratings for the same engine in different body styles of the same model. Some cosmetic additions are also being worked on to make reading the large pages easier.
GM and Mopar hp changes are done. Some of early Ford.... I am reviewing everything!! If you find something that is not right, please let me know!!
Thanks for all the support!
Dwight Southerland
Old 12-29-2015, 09:26 AM   #54
Dragsinger
Liked 99 Times in 60 Posts
Mr Southerland,
This is a work to be commended, Thank You.
Larry Woodfin 471W
Old 12-30-2015, 08:06 PM   #55
Dwight Southerland
Default End of 2015 Updates Are Done!!
Thanks for the encouragement, Larry!
The latest power factor changes and tech bulletin updates are done!
Old 01-01-2016, 02:19 PM   #56
Dwight Southerland
1/1/2016 New stuff for ClassRacerInfo web site!!
  • All the changes from NHRA in the class guides (new power factors) and tech bulletins are in the database.
  • The new F/SAA class added to classifications. (I guessed on the indexes since NHRA has not published them yet.)
  • Fixed some bugs that kept from calculating correct classifications when multiple factors were applied to different bodies of the same model car. This especially affected the 1971-74 Mopar 340 cars.
  • Added panel background coloring for the classification grids so that all the data for a particular engine is easier to visualize on the chart.
  • Added the dates of the power factors to the classification grid.
Currently working on:
  • A way to show odd power factors for the same engine like ram air options, the 63-64 Chevrolets with differences for the WCFB and Rochester carbs, the Chev 454s with the 236 vs the 292 heads, and others.
  • Adding text information for engines and cars. (more on this later!)
Enjoy!!
Dwight Southerland
Old 03-07-2016, 02:47 PM   #57
Dwight Southerland
If you haven't noticed, the AHFS changes from 3/1/16 have been added to the database.
Old 03-08-2016, 09:17 AM   #58
Billy Nees
OK? Did you miss the Maverick?
Billy Nees 1188 STK, SS
Old 03-08-2016, 04:33 PM   #59
Dwight Southerland
?? No.
Old 03-22-2016, 07:52 AM   #60
Dwight Southerland
All the changes from NHRA Tech and the AHFS are now in the database:
1) Adding the P5155469 MoPar Performance cast iron replacement head to the 68-89 318, 340 and 360 engines for SS and the 92-02 Dodge truck 318 and 360 engines for Stock.
2) Correction of the head and intake casting numbers for the 77 Ford 302 engines.
3) Addition of another set of carburetors (big ones!) for the 67 Ford 427-425.
4) Horsepower factor change for the 2010 Cobra Jet 352-385hp automatic for Stock.
NHRA's announcements are here - http://www.nhraracer.com/
