Old 03-11-2016, 11:39 AM   #1
Dave Gantz
Liked 251 Times in 125 Posts
Default SBC Oil Pump Bolt Torque
7/16-14
Several online sources say 65# for a SBC oil pump bolt. A bolt torque chart says 70# dry and 55# oiled, for a grade 8 bolt, which it is. (6 radial lines)
The bolt started crushing the oil pump before the wrench clicked. It's the same pump I took off.
I yam con-fused.
It's a 94-ish 350 crate motor in a work van.
Old 03-11-2016, 11:58 AM   #2
richie 2
Liked 205 Times in 93 Posts
Default Re: SBC Oil Pump Bolt Torque
#50 oiled is my number. check yer wrench...
Old 03-11-2016, 09:19 PM   #3
Ed Wright
Ed Wright's Avatar
You should also have the part of an oil pump bolted to the rear main cap when you have it align honed. The better shops I have been to all do that. Same torque on the bolt when installing the pump. I always used 50lbs, lubed.
Ed Wright 4156 SS/JA
Old 03-11-2016, 10:40 PM   #4
Adger Smith
Liked 880 Times in 311 Posts
Ed is spot on.
The rear main will go out of round just like using or not using a TQ plate on the deck for the cylinders. I always align hone with 55 & oil on a bolt, a stud @ 50 with moly lube when I align hone and assy. I use my same assembly TQ wrench on it, too It is critical. Why even bother align honing if you are going to pull it out of round when you put it together??
Adger Smith (Former SS)
Old 03-11-2016, 11:47 PM   #5
Ed Wright
Ed Wright's Avatar
I always use a stud for the pump. Should have included that.
Old 03-12-2016, 10:25 AM   #6
Dave Gantz
I will check the wrench. It's a Snap On, I guess I could give it to the local Snap On guy for calibration. It's never given me any issues, and I had just torqued the rods previous to "torquing" the pump. But, anything can happen.
I'll try 50# oiled, when I get the new pump.
Thanks for the advice on the align honing. It's in a work van.
Old 03-13-2016, 12:03 PM   #7
Eman
Liked 133 Times in 76 Posts
Last time I sent my Snapon torque wrench for 'recalibration" it was a lot more pricey than I thought it should be. I'd just find a couple of friends with wrenches and compare torque some bolts. ARP used to ck your wrench for free at national events.
Old 03-13-2016, 07:03 PM   #8
richie 2
I cant imagine crushing the pump housing...where did that pump come from?
Old 03-14-2016, 08:54 PM   #9
Dave Gantz
It was on the engine when I got it. I could feel it giving as I pulled on the wrench. It didn't feel as if the bolt was breaking; it just kinda kept going. Hard to explain. The area that crushed is right under the bolt head. It's why I kind of figure the wrench is okay. It feels the same tightening other bolts as it aways has. -Certainly not a calibration test.
I haven't looked at it closely yet. I'm working under the truck and was more than ready to quit when I felt that!
I have the new one. I'll try posting pictures of each.
Old 03-16-2016, 04:58 PM   #10
richie 2
sneak up on the #50. let it sit for 15 minutes before heading to the final number. Im hearing horror storys on the redesigned & fragile sbc M55 pump housings from mellings....
