Old 03-11-2016, 08:04 PM   #11
Ron Gusack
Ron Gusack's Avatar
Liked 7 Times in 6 Posts
Default Re: Windage tray
Originally Posted by PETE PEERY View Post
The rear cylinders move a lot of air on their way down so i think it is very important to have some type of baffle obstructing this. You can weld it to pickup tube or attach to pan but just do not want the air blast to have direct path to pickup area. just my opinion.
How big would this baffle be?
Ron Gusack is offline   Reply With Quote
Old 03-11-2016, 09:14 PM   #12
Ed Wright
Ed Wright's Avatar
Oil also tries to climb up the back at launch. I have a baffle trimmed to fit the pan, bolts between the oil pump and main cap. Seems like it was from Moroso. Probably had it 5 years or so.
Ed Wright 4156 SS/JA
Old 03-11-2016, 09:43 PM   #13
PETE PEERY
Liked 33 Times in 11 Posts
Depends on size and shape of pan. Just take a pump with pickup and place in pan approximately in position and look at it. All you are trying to do is shield the oil at pickup area from air blast. Does not have to be pretty only needs to protect. Just use line of sight.
PETE PEERY is offline   Reply With Quote
Old 03-11-2016, 10:09 PM   #14
Ron Gusack
Ron Gusack's Avatar
I 've one of those for years. My car doesn't wheelstand very high but I guess it doesn't hurt to run it.
It's surprising how opinions differ on trays. The talk used to be that we had to have a tray to break up the rope of oil swirling around the crank. My pan still has the factory two piece solid pan welded in. It's pretty far from the crank. I leave it in cause I feel like it helps keep oil in the sump during shut down.
Old 03-11-2016, 10:21 PM   #15
Ed Wright
Ed Wright's Avatar
The scraper is for the "rope of oil" on the crank.
I can see what Pete is talking about. I might should look into that.
Old 03-11-2016, 10:48 PM   #16
joespanova
Liked 13 Times in 11 Posts
In my Moroso older Ultimate 2 pan it came with a diamond stripper and that's what I still use........and its easy to imagine why it would work , better than a tray. The Ultimate 2 pan has a full kickout and seriously altered sump......uses tubes through sump to pan rail.
Funny thing is , when I was talking to a "good guy" at Moroso 2 weeks ago , he wanted to sell me a newer pan , one that uses a TRAY........the pan looked much simpler than the pan I have. He told me the newer pan was worth 15 HP..........I didn't buy it . The pan he suggested is below. This pan looks much cheaper to produce than what I have now ( Ultimate 2).
Old 03-11-2016, 11:50 PM   #17
Ed Wright
Ed Wright's Avatar
I use that Moroso pan as well, with that tray tossed under a work bench.
Old 03-12-2016, 12:07 AM   #18
Alan Nyhus
Liked 800 Times in 237 Posts
"That'll never work....."
Old 03-12-2016, 12:09 AM   #19
Ed Wright
Ed Wright's Avatar
Where's the Like button?
Old 03-13-2016, 12:09 PM   #20
Eman
Liked 133 Times in 76 Posts
For what it's worth I called Milodon a while back and asked the difference between the screen and the tray type. Their tech preferred the tray and didn't recommend the screen.
