Liked 251 Times in 125 Posts
7/16-14
Several online sources say 65# for a SBC oil pump bolt. A bolt torque chart says 70# dry and 55# oiled, for a grade 8 bolt, which it is. (6 radial lines) The bolt started crushing the oil pump before the wrench clicked. It's the same pump I took off. I yam con-fused. It's a 94-ish 350 crate motor in a work van. |
Liked 205 Times in 93 Posts
#50 oiled is my number. check yer wrench...
You should also have the part of an oil pump bolted to the rear main cap when you have it align honed. The better shops I have been to all do that. Same torque on the bolt when installing the pump. I always used 50lbs, lubed.
Ed Wright 4156 SS/JA |
Liked 880 Times in 311 Posts
Ed is spot on.
The rear main will go out of round just like using or not using a TQ plate on the deck for the cylinders. I always align hone with 55 & oil on a bolt, a stud @ 50 with moly lube when I align hone and assy. I use my same assembly TQ wrench on it, too It is critical. Why even bother align honing if you are going to pull it out of round when you put it together??
Adger Smith (Former SS) |
I always use a stud for the pump. Should have included that.
I will check the wrench. It's a Snap On, I guess I could give it to the local Snap On guy for calibration. It's never given me any issues, and I had just torqued the rods previous to "torquing" the pump. But, anything can happen.
I'll try 50# oiled, when I get the new pump. Thanks for the advice on the align honing. It's in a work van. |
Liked 133 Times in 76 Posts
Last time I sent my Snapon torque wrench for 'recalibration" it was a lot more pricey than I thought it should be. I'd just find a couple of friends with wrenches and compare torque some bolts. ARP used to ck your wrench for free at national events.
I cant imagine crushing the pump housing...where did that pump come from?
#9 | |
I haven't looked at it closely yet. I'm working under the truck and was more than ready to quit when I felt that! I have the new one. I'll try posting pictures of each. |
sneak up on the #50. let it sit for 15 minutes before heading to the final number. Im hearing horror storys on the redesigned & fragile sbc M55 pump housings from mellings....
