Old 03-20-2016, 05:26 PM   #61
RULER
Liked 58 Times in 18 Posts
Default Re: So, what should happen to
There you go 396 has different spec than a 1970 402 this is reason for a DQ. If this was anybody else it would have been an auto DQ. Once again different rules for different folks
RULER is offline   Reply With Quote
Old 03-20-2016, 05:44 PM   #62
Liked 1,925 Times in 432 Posts
Originally Posted by Dave Casey View Post
If my memory serves me correctly,1970 has different engine specs, assuming it is a 375/396/402 combo. The exhaust valve is bigger is one differance, and the earlier cars are true 396 ci and the 70 is a 402(bigger bore) .
The 1970 is allowed a 1.88" exhaust valve, the 1968 is allowed a 1.84" exhaust valve. The dome volume and chamber volume is the same, the dome height is lower for 1970. The other difference would be the intake, if he was running the 163 intake. In 1968, the plenum divider cannot be cut, in 1970, it can. Yes, there is a 0.030" difference in bore size.
Given the car has been campaigned as a 1968 for the most part, it probably meets those rules. I don't think Clark Holroyd has been cheating up his 396 all this time, using 1970 402 specs and running it as a 1968.
My point was, you can't run a 1970 in AA/S. So if you want to run the car in AA/S, run it as a 1968, there is no disadvantage. Most are running the 401 head and the 359 intake. So the only possible advantage to the 1970 is the 0.030" bore size gain, and the 1.88" exhaust valve. Well, the cubic inch gain from a 0.030" bigger bore will be minimal, as will the unshrouding of the valves, which would be entirely negated by the 1.88" exhaust valve. Again, not seeing a real disadvantage to the 1968 combination if you want to run light and go AA/S racing. Besides, it's the only one that fits the class.
Old 03-20-2016, 07:05 PM   #63
mtkawboy
Liked 54 Times in 18 Posts
When you see a friend get DQd for class at Indy because he accidently had "ONE" TRW pushrod in his Cobrajet stocker you tend to lose respect for NHRA tech
mtkawboy is offline   Reply With Quote
Old 03-20-2016, 08:39 PM   #64
Todd Bailey
Liked 33 Times in 17 Posts
And for the record, the 68-69 Nova taillights are a little shorter than the 70-72 taillights so the interchangeability is not there without modification to the taillight panel.
Todd Bailey is offline   Reply With Quote
Old 03-21-2016, 07:33 AM   #65
Billy Nees
Liked 7,902 Times in 1,754 Posts
Jimmy Alund withdrew from the race. Jimmy is a straight up guy, he loves stock. He felt it was the right thing to do. There was some confusion on the class he could run. By no means did Jimmy want to circumvent the rules. Rules are rules and Jimmy was man enough to do the right think. I hope all of you will support Jimmy in the future and not hold this against him. He came along way to support the class, and for me, that says it all.
So there you have it! Thank you, Jimmy. You did the right thing and preserved the integrity the class.
The End.
Billy Nees 1188 STK, SS
Old 03-21-2016, 07:59 AM   #66
rod butcher
Liked 132 Times in 27 Posts
Originally Posted by billy nees View Post
so there you have it! Thank you, jimmy. You did the right thing and preserved the integrity the class.
The end.
x2
rod butcher is offline   Reply With Quote
Old 03-21-2016, 08:14 AM   #67
Bobby DiDomenico
Liked 103 Times in 53 Posts
How difficult would it be for NHRA to have a "Go/No Go" computer at tech in where the year/engine/class claimed is entered and it either passes or is flagged prior to credentials?
Old 03-21-2016, 09:17 AM   #68
Bob Don
Bob Don's Avatar
Liked 905 Times in 193 Posts
At the New England National Open last year, everyone's class/combination was verified during the tech in process. It added about 2 minutes or so to tech. No big deal.
Bob Don 128 SS
Bob Don is online now   Reply With Quote
Old 03-21-2016, 09:56 AM   #69
Adger Smith
Liked 880 Times in 311 Posts
OH, they would have to pay someone to come up with the program and maintain it as well as administer it at the races. Administering it at the races would require another step in Tech. They can't afford to do that when it is to the racers benefit to learn how to class his own car and fill out the paperwork correctly. They can't afford to be responsible for anything like putting a car in a class. Having that step in Tech would imply responsibility and possibly leave them open to law suits. OH, yea now I remember that could be the reason the process is the way it is now. Someone sued them for putting them in the wrong class & it put a financial burden on them. The last thing that should happen is a financial burden be put on the racer.
Adger Smith (Former SS)
Old 03-21-2016, 10:30 AM   #70
Dave Casey
Liked 804 Times in 168 Posts
The end.
x3
Dave Casey 1330 STK
