Old 03-21-2016, 07:09 PM   #41
joespanova
Liked 13 Times in 11 Posts
Default Re: Oil starvation issues SBC HELP?
Originally Posted by rod butcher View Post
check #12 accusump and accumulator are same thing
Ooops........yeah I know..........sorry , I did see that too
Old 03-21-2016, 07:14 PM   #42
joespanova
You have someone like Carl Hinkson & Mike Taylor trying to help, but don't seem to want to hear what all your doing wrong.
Man you are a grumpy old azz aren't ya?
Do you read my replies? If you did you wouldn't say that.......geeezus christ. Am I dealing with men here....or women?
For the second GD time.....I AM listening / reading.
You're also the one that says throw a windage tray away when almost all others say they work?
Old 03-21-2016, 07:18 PM   #43
joespanova
Originally Posted by pmrphil View Post
Did you have the pressure drop problem on the first run also, or just the second? What kind of pressure did it carry on the first run? Where is it starting to drop (RPM, gear, how far down the track, etc.) and how far does it drop? From what to what? As much detail you can provide will give everyone looking more to see and quite possibly touch on something someone else has seen.
I dont have a data logger...........I can't answer that question
All I can share is that it dropped after the second pass. Historically that symptom equates to damage. I trailered it after that.
From what I can conclude "
A tray is better that a screen
I may need to reduce vac
I will baffle the pump as best I can
I may very well add an accusump / accumulator
Old 03-21-2016, 09:10 PM   #44
L79racer
L79racer's Avatar
What crank is in your motor? I had a very similar problem. ruined motor twice. Kept loosing pressure. Thought it was aerating oil. Tried more, then less oil. changed pump, pickups, restrictors no restrictors etc. Finally got new crank and it solved the problem. I had an eagle crank that was crossed drilled from 2006. Machine shop said that they didnt do that anymore. New eagle crank and no more problem. Sounds crazy but everything else in motor was exactly the same.
L79racer is offline   Reply With Quote
Old 03-21-2016, 11:38 PM   #45
Peter Ash
Peter Ash's Avatar
A good read on cross drilling crankshafts in high rpm engines.
http://rehermorrison.com/tech-talk-5...calls-part-ii/
Peter Ash 6100 STK
Peter Ash is offline   Reply With Quote
Old 03-22-2016, 12:00 AM   #46
Ed Wright
Ed Wright's Avatar
They know how to build one. Might ask them about windage trays.
Ed Wright 4156 SS/JA
Old 03-22-2016, 05:41 AM   #47
Greg Barsamian
Liked 427 Times in 97 Posts
Call Scott Hall @ Moroso (800) 544-8894.
Old 03-22-2016, 06:00 AM   #48
joespanova
Thank you everyone........you've all helped a lot...........
I think with all this info I have a pretty good idea now.
Old 03-22-2016, 06:19 AM   #49
joespanova
Its a BRC 4340 3.48 crank.
Its not cross drilled.
It seems like the answer is:
Std pressure pump.
A well thought out windage tray / pump baffle.
Reduce vac pump vac level.
and for me anyway , adding an accumulator just because.
I'm pretty sure the first 2 are the "focal point" for any good SS engine.
Old 03-22-2016, 08:20 PM   #50
Fred D Bartoli
Carl
Happened to notice your post about excessive bleed off with cam bearings with (3) holes. I am not a professional engine builder but I do build the motors for our super stock cars. I currently have (3) motors, (1) Dart and (2) bow-tie blks. all (3) blks. have Dura bond bearings with (3) holes. I have not had any issues with them. Just wondering how you are determining excessive bleed off, is there a specific test?. How must bleed off is considered excessive?
Fred D Bartoli is offline   Reply With Quote
