Old 03-26-2016, 07:16 PM   #21
Tony Corley
Liked 61 Times in 25 Posts
Default Re: Within Stock rules???
The Sam's guys are smart and know the rules. I would be willing to bet that they would pass teardown anywhere.
Tony Corley is offline   Reply With Quote
Old 03-26-2016, 07:36 PM   #22
Peter Ash
Peter Ash's Avatar
Stock Cars Section 10A, page 3
CYLINDER HEADS
Porting, polishing, welding, epoxying and acid-porting prohibited.
Combustion-chamber modifications prohibited
External modifications prohibited.
and from the article "http://www.enginelabs.com/engine-tec...liminator-ls7/"
“The maximum intake port volume we’re allowed is 275cc, so we milled down the intake flange surface to shorten up the length of the port just slightly. This gives us some extra room to touch up the short-turn radius, bowl, and valve job area and increase the cross-section a bit without exceeding the cc limit,” Judson reveals.
hmmm?
Peter Ash 6100 STK
Peter Ash is offline   Reply With Quote
Old 03-26-2016, 07:44 PM   #23
Tony Corley
CYLINDER HEADS
hmmm?
The heads come from the factory cnc ported. When you can start with a bare, unported version and run your own cnc program, you can make it virtually undetectable. If you read my statement, I said those guys are smart, and I would bet money it would pass teardown. And if it can pass teardown, then it must be legal, right?
Old 03-26-2016, 07:58 PM   #24
Peter Ash
Peter Ash's Avatar
After publishing their sneaky bits, they should get to experience an immediate and thorough looky loo!
Peter Ash 6100 STK
Old 03-26-2016, 08:00 PM   #25
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
These engines are 1970 Pro Stock Engines!
Old 03-26-2016, 08:04 PM   #26
Tony Corley
[QUOTE=Peter Ash;499395]After publishing their sneaky bits, they should get to experience an immediate and thorough looky loo![/QUOTE
Still willing to bet they will be just fine if they do.
Old 03-26-2016, 08:06 PM   #27
Tony Corley
They are way more advanced than that, lol
Old 03-26-2016, 08:11 PM   #28
Mike Keener
Liked 24 Times in 13 Posts
There is nothing illegal about what ERL does to an otherwise stock GM block that bears the correct casting number. Here are the facts. The GM block as it comes from the factory is JUNK and is not usable beyond .005 over bore so there is no good reason for a serious racer trying to win in the Factory Shootout to leave the "maximum allowable" over bore rule on the table just because GM built a crappy block. If GM had built a "decent block" for these engines in the first place the work ERL does would not be necessary.
The only other legal option is to run a replacement LSX block that is easily over bored to the maximum allowable specification. However, there are not to many COPO's that can deal with the extra 100 or so pounds on the nose and still be able to race at the minimum weight for the Shootout.
Why do I know this stuff you might ask? The reason is because I did it and the LSX iron block over a sleeved block that is prepped correct!y is maybe 5 hp MAX which is not worth putting 100# on the nose of the car. However, the gain from an LSX block compared to a "stock" COPO block is worth at least 25 HP, but this is largely due to the gain from the extra cubic inches that can't be achieved with a stock GM aluminum block.
Bottom line is that it costs money to go fast, and going fast just isn't for everybody. Doesn't mean those of us that wish to compete at the very highest level shouldn't be able to do it with a clear conscience as long as there is nothing illegal in doing so.
Mike Keener
A/S B/S
C/SM
Mike Keener is offline   Reply With Quote
Old 03-26-2016, 08:14 PM   #29
Ed Wright
Ed Wright's Avatar
Very well said.
Ed Wright 4156 SS/JA
Old 03-26-2016, 08:14 PM   #30
Tony Corley
Great reply Mike Keener^^^^^^^^^
