Old 03-28-2016, 09:20 PM   #11
kansas stocker
Liked 250 Times in 49 Posts
Default Re: A follow up to "oil starvation issues" thread
Are you positive that you had .003 on all mains? Have a circle track friend that had exactly the same results that you have had with the same little m block. His engine builder missed it twice and now he has a new builder.
Pete
kansas stocker is offline   Reply With Quote
Old 03-28-2016, 11:09 PM   #12
joespanova
Liked 13 Times in 11 Posts
Originally Posted by HP HUNTER View Post
Listen to this post.
We refer to "wet mag" as an FPI process in aviation.
Fluorescent penetrant inspection (FPI )
I've never heard it referred as "wet mag".......but I believe that's what you or Mike mean.
And yes , I have the option of using traditional mag or FPI.
Old 03-28-2016, 11:11 PM   #13
joespanova
Pete
I am 100% positive. I am the "builder" . I am a "machinist" of 40 years and use the most accurate currently available gauges used in our shop ( aircraft ).
Old 03-29-2016, 08:18 AM   #14
joespanova
Old 03-29-2016, 08:22 AM   #15
joespanova
Old 03-29-2016, 08:24 AM   #16
joespanova
Old 03-29-2016, 08:26 AM   #17
joespanova
SO ........there ya have it.
Disgusting isnt it.........
Old 03-29-2016, 08:35 AM   #18
Alan Nyhus
Liked 800 Times in 237 Posts
Glad you caught it before things turned into shrapnel. Amazing how the rod brgs. look perfect and the mains are hammered. Aeration, too much oil upstairs, an internal leak...likely a combination of things. Are you going to change where you source the vacuum or eliminate the pump all together?
"That'll never work....."
Old 03-29-2016, 09:11 AM   #19
carl hinkson
Liked 18 Times in 10 Posts
The mains have a constant load where the rods don't.
At least its on one piece and you still have something to work with!!!!
carl hinkson is offline   Reply With Quote
Old 03-29-2016, 09:17 AM   #20
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 313 Times in 106 Posts
wet mag is FPI when translated from hillbilly. Use the FPI on crankshaft.
If I didn't know anything about this crank and came into my shop,my first guess is it's cracked and would be surprised if it isn't.
I can't tell in picture but has the radius been ground less than original. Been reground and radius reduced? Normally BRC or any aftermarket crank would have 1/8 (.125'') radius at the least,can't tell about crank in picture,but rod bearing doesn't look like it would clear a .125'' radius,looks like it doesn't have the chamfer or narrowed to clear, if radius has been reduced that weakens crank.
Mike Taylor 3601
Mike Taylor 3601
