Old 03-30-2016, 07:20 PM   #11
ken robinson
Liked 225 Times in 88 Posts
Default Re: Fuel pressure inconsistency run to run Aeromotive
I run this set to . Check the volts when you check psi . Pack/fill the cell but don't let it cover/flood fuel cell vent . What return set up did you make inside your fuel cell so you reduce air bubbles from the pump inlet . Do you run 12 battery set up w/alter ? I do with a 55amp alter. / If it all tests ok . call them before the warranty ends . Let me know what fixed it .
Old 03-30-2016, 07:29 PM   #12
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Originally Posted by Rusty Davenport View Post
A little further clarification----there is no difference in gauges of Autometer on the cowl and Aeromotive at the carb, they are consistent with each other. The car can sit still for an hour or the next day and have a different pressure everytime it is started and can be higher or lower from where it was at the last run. ??????
liquid(glycerin) filled gauge(s)?
https://aeromotiveinc.com/fuel-press...blem-solution/
Old 04-06-2016, 07:25 AM   #13
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 316 Times in 107 Posts
Had customer pulled his hair out over fuel pressure,would be 6-7lbs. then next thing you now would be 2-3lbs then back. changed regulators 3X,checked pump out,looked OK,he bought a new aeromotive just like he had,same thing. He found out line was sucking together between tank and pump, just took him 2 weeks to figure it out.
Mike Taylor 3601
