Old 03-30-2016, 02:43 PM   #81
Robert Simpson
Liked 20 Times in 12 Posts
Default Re: Within Stock rules???
From the NHRA Rule book
“Must be correct casting number for year and horsepower claimed, per NHRA Technical Bulletins or NHRA accepted. Porting, polishing, welding, epoxying and acid-porting prohibited.”
Based on this how is this motor legal?[/QUOTE]
If I remember correctly the heads were CNC from the factory? If that is the case how can NHRA prove that additional CNC had been done? Short of the cc's? When I first saw several years ago where CNC heads were installed on some of the super cars that clearly opened the door for additional porting. The thing I don't get from the article is the changing of the cam, to a larger grind? How can you tell this "Stocker" engine from a "SS" engine??
Robert Simpson is offline   Reply With Quote
Old 03-30-2016, 03:10 PM   #82
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
On the subject of the porting, you are correct. This was an issue on the SS AMX heads throughout their history. How do you know what is correct?
As for the camshaft specs, the .641" lift is what is in the Tech Bulletin, regardless of any advertising for the LS7. I suspect that some of the confusion is that people assume this engine is the same as the LS7 engine installed in Corvettes, but it is not. It is a spec engine for their Factory Shootout cars, not a production engine.
Old 03-30-2016, 05:36 PM   #83
Alan Nyhus
Liked 800 Times in 237 Posts
For most, the real issue is what the rule book says and what is currently being done and allowed .
Isn't it time for the rule book to reflect what is currently being done? For a racer to spend $1000+ to cover up what isn't being enforced certainly doesn't help the racer.
Maybe it's time for the rules to state: If the ports meet the CC's, the valve sizes are correct and there's no welding or epoxy, they pass.
"That'll never work....."
Old 03-30-2016, 05:41 PM   #84
GTX JOHN
I agree with you on this one Alan!
Not that I expect anything to every change
except maybe to get worse and more expensive!
John Irving
741 Stock
741 Super Stock
Old 03-30-2016, 06:05 PM   #85
Dwight Southerland
That is exactly how the rule for porting in Super Stock was originally written. Given time and pressure, you have the current Super Stock head rule. Is that what you want? Be careful what you ask for or how brilliant you think your solution will be or what you give in to.
Old 03-30-2016, 06:15 PM   #86
Ed Wright
Ed Wright's Avatar
Just what I was thinking.
Ed Wright 4156 SS/JA
Old 03-30-2016, 09:01 PM   #87
Liked 1,922 Times in 432 Posts
Dwight, you ain't just whistlin dixie, bud.
I know a couple of guys who could push some fast Super Stock heads through those loopholes. It's bad enough as it is.
Old 03-30-2016, 11:06 PM   #88
Alan Nyhus
All very good points, Dwight. -Al
Old 03-30-2016, 11:15 PM   #89
novassdude
Liked 136 Times in 49 Posts
If I remember correctly the heads were CNC from the factory? If that is the case how can NHRA prove that additional CNC had been done? Short of the cc's? When I first saw several years ago where CNC heads were installed on some of the super cars that clearly opened the door for additional porting. The thing I don't get from the article is the changing of the cam, to a larger grind? How can you tell this "Stocker" engine from a "SS" engine??[/QUOTE]
In this case it wouldn't be very hard they bragged about it in a magazine article.
novassdude is offline   Reply With Quote
Old 03-31-2016, 10:44 AM   #90
Tony Corley
Liked 61 Times in 25 Posts
Originally Posted by Erik Jones View Post
Sorry but its not impressive.....and i think its lame to write an article like this on how "trick" they are for doing things that have been going on for ever in Stock...And as someone who makes there living in Stock and Super Stock i think those things should go unspoken, especially in writing!
Except what you are forgetting is that this is a school doing this. They disclose what they are doing because they use it as a teaching tool. Although I have not seen them at a NHRA race, if they are staying true to form from their NMRA days, they have their actual students working at the races. I think its cool that they are opening up and sharing with the masses , and at the same time training the next generation of engine builders.
Tony Corley is offline   Reply With Quote
