Old 04-06-2016, 04:37 PM   #41
Dick Butler
Liked 32 Times in 19 Posts
Default Re: motor home safety
M.H size new Bridge stones now on sale100 $off. 459/ tire
These are the brand new design to improve mileage.
Old 04-06-2016, 04:43 PM   #42
Mike Pearson
Mike Pearson's Avatar
Liked 1,987 Times in 599 Posts
I just paid $529 each for Michelin steer tires.
Mike Pearson 2485 SS
Old 04-06-2016, 05:49 PM   #43
V M Kauffman
Before just going out and buying new steer axle tires do yourself a favor hook up and go weight each axle fully loaded. Michelin has a steer tire 315/80 R 22.5 it is either a 22 or 24 ply good for 15,000 lb load a lot of Prevosts use these as they are very heavy on the front. They aIsland use these for the single rear tag axle. Alcoa also makes a 9 or 10 wide wheel for these tires.
V M Kauffman is offline   Reply With Quote
Old 04-06-2016, 08:34 PM   #44
Ed Wright
Ed Wright's Avatar
I put all six on mine when I bought it had them all the way around on my last one also. When Jeff recommended 10 ply 16" LT tires to me when I blew out a 15" Goodyear trailer tire when the trailer wasn't a year old, Jeff Tueton recomended me going to those tires and wheels. Michleans on my trailer too. Motor homes both drove better, trailer tows better. Especially in cross winds. I thing the original trailer tires were rolling over in strong cross winds, and when passing 18 wheelers. None of that now. I have used Michlean tires on our passenger cars for over 30 years now. Won't use anything else now.
Ed Wright 4156 SS/JA
Old 04-07-2016, 01:45 AM   #45
davebw31
Ed Wright:
Goodyear Marathon radial trailer tires since I do not know when are made in CHINA....! I have learned "due to quality and reliability issues" they are reopening their plant in Brazil to start making them there again.
Three years ago I bought two (was not happy they were made in China) for my Pace 24' trailer and one lasted a little over one year with it being destroyed when it blew! I moved the two older ones made in Brazil to the rear and the China ones to the front and I am keeping my fingers crossed.
On my open 18' trailer I have Maxx brand 10 ply (load range E) 205X75R15 radials that were take offs from a local RV dealer about 4 yrs ago and are doing fine.
I have talked to fellow racers and seen LT truck tires now being used on trailers. Cost more, however they last!
davebw31 is offline   Reply With Quote
Old 04-07-2016, 06:04 AM   #46
Dick Butler
New tires (bridge stones) definitely show much softer ride. Confirms old tires were stiffening or harder w age. Load range G I believe
Old 04-07-2016, 07:25 AM   #47
jmcarter
jmcarter's Avatar
Liked 3,249 Times in 988 Posts
Goodyear Marathons are absolute junk (fortunate one blowout north of Atlanta on I-75 wasn't a bigger disaster)...MAXXIS makes several good alternatives with higher load rating if you don't want to resort to LT tires for whatever reason. Just bought a MH with Goodyears and will be switching to Michelins at first opportunity (after Uncle Sam gets his check of course).
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 04-07-2016, 08:29 AM   #48
mykids
Liked 2 Times in 1 Post
If you are planning on going through Massachusetts this summer with your Coach and a trailer in tow - my best friend had to attend a DOT safety meeting for the construction company he work's for and the DOT officer brought up Motor Homes and said there intent was to have a DOT officer parked before the weigh stations and directing you to go to the weigh station ( even though you are not mandated to do so) - they will then conduct a modified DOT check up for proper air pressure - lights - tire condition - safety chains - I am sure being Drag Racers we all leave home with clean rig's as I have always told my son to run with the lights on and make sure it was washed - just a head's up - Bob
mykids is offline   Reply With Quote
Old 04-07-2016, 08:30 AM   #49
Rsmith38
Liked 28 Times in 15 Posts
Years back we started having tire troubles on out 26' tandem trailer.
Turned out that the Goodyear Marathon trailer tires are made in load range C and D. Only difference is the C or D about 1/16" high on the sidewall. Even dealers didn't know the difference until we bought a replacement from a FL dealer. We were unknowingly replacing Load range D original tires with lighter C tires - Doesn't work well on 10K trailer!
Check the load range on Marathons!
Rsmith38 is offline   Reply With Quote
Old 04-07-2016, 09:46 AM   #50
Mile High
Smile Re: motor home safety
The proper load range and air pressure are very important. My motorhome came with Michelins and will always have Michelins. Family Motor Coach Association has a discount program for Michelin tire.
https://www.fmca.com/benefits/michelin-advantage.html
Most trailer tires aren't rated for speeds over 65MPH. Slow down and enjoy the ride. I see many RVer's blow past me when I'm doing 65. I know we want to get there just take it easy. 65 MPH is enough.
Jeff
Street legal 64 Falcon Sprint with 410W living in Texas.
Stock - Super Stock fan
Mile High is offline   Reply With Quote
