Old 04-04-2016, 07:45 PM   #1
Dragsinger
Liked 99 Times in 60 Posts
Default valve to piston checking tool
This is without question a positive checking tool
ID:	33219   Click image for larger version
Larry Woodfin 471W
Old 04-05-2016, 11:35 AM   #2
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
Default Re: valve to piston checking tool
Send it back, Larry. Got to be a cheap Chinese piece and won't last a week. Look at that machining! What did they cut it with, a rip saw?
Woodfin deserves Shiny!
Dale
Dale Shearon
68 Mustang 6394
Old 04-05-2016, 11:48 AM   #3
NORMAN BARNARD
Liked 2 Times in 2 Posts
well "duh"....did it come with a manual????
NORMAN BARNARD is offline   Reply With Quote
Old 04-05-2016, 12:00 PM   #4
Dragsinger
I had a lumber jack cut it with a chain saw
Larry Woodfin 471W
Old 04-05-2016, 12:06 PM   #5
Dragsinger
seriously,
because of angle milling and valve radius etc it is only specific to my engine. I initially cut the damaged head out of curiosity then realized it could be a cool visual aid.
I may touch up some of the chain saw marks with a rasp
Larry Woodfin 471W
Old 04-05-2016, 04:43 PM   #6
Ed Wright
Ed Wright's Avatar
I made a little fixture that hooks on my Jessel rockets at the push rod end, uses a 1/2" break over, using the actual heads & used head gaskets, "checking springs" installed, pull the valve down against the piston, measuring actual travel. Ex from 10 deg BTDC, until TDC. Intakes from TDC. to 10 deg ATDC. Two degree increments. I have checked mine with checking springs vs racing springs. On mine, subtract about .004" from the checking spring VTP clearance. I have learned how much I need with checking springs, so only check it that way now.
This works for me. If a pro has a different recommendation, I defer to them. This is just how I have done it for several years.
Ed Wright 4156 SS/JA
Old 04-07-2016, 10:28 AM   #7
Mike Fuller
Liked 203 Times in 80 Posts
This has worked great for me for the last 25 years.
Mike Fuller 396 STK
3961 SS
Old 04-07-2016, 10:44 AM   #8
west coast
Liked 230 Times in 75 Posts
I don't use checker springs anymore because the difference between them and the real ones is a lot bigger spread then what Ed is seeing on his combo. Everybody's combo will be different.
James Boyce 6052 K/SA Stock
National record holder 2015,2018,2 times in 2022,2023
west coast is offline   Reply With Quote
Old 04-07-2016, 10:59 AM   #9
FireSale
FireSale's Avatar
Jim, Mike and whoever:
Since what you're measuring is the distance from the seated valve to the top of the piston, why does it matter what weight spring is holding the valve closed? I know we are talking several hundred pounds of pressure difference between checking and racing springs, but at 0 rpm seated is seated?
Dale
Dale Shearon
68 Mustang 6394
Old 04-07-2016, 12:31 PM   #10
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
Deflection in the valve train with the high pressure springs. Try it both ways and see for yourself.
Dwight Southerland is online now   Reply With Quote
