Liked 39 Times in 5 Posts
Looking for some ideas on the cause. Car is leaving very lazy and has a hesitation at the hit of the throttle. It cleans up and runs strong after about 4,500 in first gear. Tried a spare carb, but unsure if it was good or not, and had the same results. Swapped converters to a known good one and replaced the ignition coil. The fuel pressure is staying steady at 7 1/4. The car is a 72 454 Corvette running in C/SA. The motor is fresh/new and was dynoed. Neither my carb or igntion were part of the dyno testing. Both sat for about a year without usage. Let me know if you have any ideas on what to look for/test. Thanks
Norm Webber
Norm Webber |
Liked 510 Times in 117 Posts
Try the fuel pressure at 6 psi for starters. Trans oil level is OK? If you use a 2 step change the 2 step module. Had one go bad when we had our Malibu stocker causing same grief.
68 Chevy11 327 F/S Last edited by Bob Gullett; 05-01-2016 at 01:46 PM. |
Liked 319 Times in 68 Posts
Fuel sloshlng over?
Lee Valentine 1661 STK |
No on the fuel sloshing as it will act similar in park stabbing the gas. Checked the fluid and it is ok. I tried leaving without the two step and had the same results. I will try the fuel pressure on the next run. Thanks for the ideas
Norm Webber |
Liked 231 Times in 107 Posts
Squiters doing as they should? Good flow out of both sides? Rear air flap OK?
Liked 121 Times in 11 Posts
Check the accelerator pump gasket, they dry out from sitting especially after using VP fuels. Chased that for a while once.
Joe DeMarzo 1317 STK |
Liked 133 Times in 76 Posts
Described hesitation is usually too much or too little fuel. Too much and you'd get a black puff when it finally picked up. Too little and it's just a dead spot. I'd bet too little. I'd start by dissembling carb and cleaning thoroughly.
What carb does it have? |
X2.............Sound like Carb.
Liked 68 Times in 26 Posts
how much timing are you using? where is your total set at ?what rpm? just curious
Liked 880 Times in 311 Posts
Change the coil wire!
Adger Smith (Former SS) |
