Old 05-08-2016, 09:05 PM   #1
mfranchett
Default 64 or 65 Chevelle chassis questions
I am thinking about getting a 64 or 65 Chevelle and while researching them I have read where the frame is a weak point in these cars. I figured someone running one of these in stock or ss could tell me what needs to be done to stiffen the frame.
mfranchett is offline   Reply With Quote
Old 05-09-2016, 12:25 PM   #2
tj310
Default Re: 64 or 65 Chevelle chassis questions
Don't know if they'r any worse than other 50 year old cars , especially if it spent any time in the rustbelt . ---Trevor
Old 05-09-2016, 04:28 PM   #3
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
If you install a roll cage it will stiffen the frame, also there is available a pair of stiffeners that connect the front pickup points of the upper and lower rear control arms .
Old 05-09-2016, 09:06 PM   #4
Mike Brogniez
I think convertibles had boxed frames.
MB
Old 05-09-2016, 11:45 PM   #5
prostockpete1
Liked 90 Times in 52 Posts
When I built my "65 283 SS / MA Superstocker in the late 70"s to stiffen the whole combination I removed all the rubber body mounts from both sides of frame & made new ones by cutting up 2 inch dia. pipe with thickness matching old rubber spacers & welding large washers to both sides .jacked up body carefully & slipped my new creations in the origin positions of old mounts with long bolts / nuts after using round hole saw to access the ones that came thu body to tighten . opened the doors when finished to find no binding . 8 point cage tied including vertical bars down thu floor to new crossmember front ladder bar pickup points made a solid combo in its day .. that's my chassis story
prostockpete1 is offline   Reply With Quote
Old 05-10-2016, 06:08 AM   #6
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
why and what do you plan to do with it?
Old 05-10-2016, 06:52 AM   #7
bigfoot584
Hate to pop your bubble, but that's the same basic design used from
'64 thru '87 in the mid size GM line. When the bodies were removed
you could damn near twist the front 45 degrees before the back
would lift off the ground, the body is where most of the structural
strength came from, but that's for normal driving. Wheel standing
high HP cars need added strength in the form of a roll bar and or
cage to reduce or eliminate it.
bigfoot584 is offline   Reply With Quote
Old 05-10-2016, 07:44 AM   #8
mfranchett
Thanks for the info. As for what I plan on doing with the car it will be something I will use for the street and hopefully work up to street/strip. Something I can work at over time. Do not if I wil ever make it a class car although I would love to.
Old 05-10-2016, 08:02 AM   #9
1320racer
1320racer's Avatar
unless, you're are in love with the 64/65 body, my advice is to look at a later model Chevelle which has better resale and unlimited parts supply. That said, there is no issue with the frames under GM A body cars.
