Old 05-16-2016, 12:54 AM   #1
Jim Johnston/6022
Liked 13 Times in 6 Posts
Default jesel belt drive question
I am able to move crank 3 degrees back and forth with no top gear or valve train movment. Put an old used belt on and there is very little movment-maybe 1/2 degree, the same as an old comp. cam unit the jesel unit replaced.
jesel says 3 degrees is normal and i could send the belt to them to measure. I bought a new belt and it is the same ( 3 degrees) as the original with 72 runs.
The questions are why would there be a difference and would it effect valve timing and or performance.
jim johnston ss/oa
Jim Johnston/6022 is offline   Reply With Quote
Old 05-16-2016, 08:39 AM   #2
Jim Hanig
Liked 99 Times in 49 Posts
Default Re: jesel belt drive question
I find the same thing on mine, the comp belt drive is a little less.
Old 05-16-2016, 12:53 PM   #3
bigfoot584
Possible line honing, shortening the dim. between gears?.
bigfoot584 is offline   Reply With Quote
Old 05-17-2016, 09:16 AM   #4
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 308 Times in 103 Posts
If I remember correctly, Jesel has belts for align bore/honed blocks.
Mike Taylor 3601
Old 05-17-2016, 09:19 AM   #5
Ed Wright
Ed Wright's Avatar
Mike Taylor 3601
Yep. I use one.
Ed Wright 4156 SS/JA
Old 05-17-2016, 05:03 PM   #6
Jim Johnston/6022
Thanks for the replies - it appears it is a hit or miss deal to get a belt that is tight. The fact is that a 5 year old used of the shelf jesel belt and a much used comp. cam belt unit seem tight,new jesel belts not,all on the same engine.
The question still remains what would this do to cam timing and or performance.
jim johnston ss/oa
Old 05-17-2016, 07:07 PM   #7
FED 387
Liked 333 Times in 180 Posts
Problem might be that the teeth on the belt DO NOT match the tooth spacing on the pulley--- take a close look at the interaction between the teeth on the belt and your pulley happened to us before might have to try several gilmer belts til you get one that fits "just right". Fed 387
