I see them in the Blueprint guide, what type of head would these fall into? Wedge or inline? I know it may be a disadvantage but can you run an inline head in a higher class that specifically calls out a canted or splayed head or is it limited to the lower class?
#2 | |
Liked 1,586 Times in 583 Posts
Colby, The term "inline" valve deals with the location of the valve in relation to the adjacent valves. The term "wedge" deals with the shape of the combustion chamber. The LS family of cylinder heads are inline with a "bathtub" style combustion chamber. Hope this helps. |
So where would this head fall class wise in Modified or Modified Stock?
Liked 9 Times in 3 Posts
it can run in ss/as or ss/bs not c/s since it's aluminum.
Mark Markow 171 ss/tb |
Mark is correct.
There is a cast iron LS6 head that was, used in the LQ4, 6.0L engine with both cast iron block and heads. They are a copy of the LS6, 15 degree head with cathedral ports. SS/AS is a difficult class because they also allow splayed valve heads. |
Liked 880 Times in 311 Posts
I have always wondered if you could use the iron LS heads successfully in SS/CS. It would be easy to build a small 286 cu in LS to make class minimum weight. Has anyone tried it?
Adger Smith (Former SS) |
#8 | |
It should make some crazy power in SS/CS. As cast, the cylinder head has a 210cc intake port volume. They are also cheap the same with the 6.0 cast iron block. I don't think anyone has built one yet. |
Liked 974 Times in 310 Posts
Can't use those cast iron heads in ss/cs. Heads were only available on a truck...........Unless nhra changed their ruling on this.
Glenn, they changed their ruling and the cylinder heads can used in the Modified class only. Not in the regular SS or GT class.
