Old 05-18-2016, 06:09 PM   #1
Robert Simpson
Liked 20 Times in 12 Posts
Question Best lifter?
I would like to know what lifters people recommend for a sbc Hyd stocker combo. I am putting it back together and don't want to use the shubecks. I have a new cast iron cam that has been nitrated. I would like recommendations and can you use them from cam to cam? Is there a break in process? Thanks
Robert
Robert Simpson is offline   Reply With Quote
Old 05-18-2016, 09:45 PM   #2
Steve Williams
Default Re: Best lifter?
Trend http://trendperform.com/c-1149649-lifters-tappets.html
Steve Williams is offline   Reply With Quote
Old 05-18-2016, 11:51 PM   #3
J.R. Haddad
Liked 1,471 Times in 308 Posts
CLIFF SHERMAN, J.Allen's Dad. (225) 323-0052.
J.R. Haddad is online now   Reply With Quote
Old 05-19-2016, 11:53 AM   #4
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: Best lifter?
Originally Posted by Steve Williams View Post
"Low Movement Solid Flat Tappet Lifter"
What is that suppose to mean? Seems like a contradiction of terms or is that their interpretation of a hydraulic lifter?
LOCOMOTION Racing
Old 05-19-2016, 12:57 PM   #5
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 319 Times in 108 Posts
I use precision products performance center(PPPC) tool steel lifters, they oil the rockers right( don't flood) and have ran them 450+ runs with 475lbs springs.
Break in required,using 1409Xpac spring' I break in with stock LS springs,was using break in rockers but springs now have too much pressure,break in rockers won't drop it low enough to be safe.
springs are easy to change installed height set, so just pop LS off and 1409X right back on.
If lifter has .015'' travel it is considered "hydraulic".
Mike Taylor 3601
Old 05-19-2016, 05:27 PM   #6
Robert Simpson
Mike do you use them on a cast cam? Also, can you use them from cam to cam? Adhering to the break in process of coerce. Thanks to all the reply's please keep them coming.
Robert
Old 05-19-2016, 06:32 PM   #7
Liked 1,924 Times in 432 Posts
You can refinish some tool steel lifters to allow them to be used on a different camshaft, they must be sent back to the lifter manufacturer. In order to be able to move a tool steel lifter to a different camshaft or lobe, it would need to be DLC coated. You cannot run DLC coated lifters on a cast iron core cam. You can use un-coated tool steel lifters on a cast iron camshaft, whether the camshaft has been nitrided or not.
I use Trend lifters.
Old 05-20-2016, 09:16 AM   #8
Liked 11,006 Times in 2,263 Posts
Using PPPC coated lifters on steel cam so far so good! I still keep my fingers crossed.
Old 05-20-2016, 09:37 AM   #9
Rusty Davenport
Liked 101 Times in 27 Posts
Robert
Comp Cams takes an order over the phone for a stocker cam........are you getting a steel or a cast iron cam ???? Does the cam spec card spell it out ???? Never been ask that question.
NHRA AND IHRA STOCK ELIMINATOR 2772
Rusty Davenport is offline   Reply With Quote
Old 05-20-2016, 06:24 PM   #10
Comp will ask you what core you want. I'd say 90% of the flat tappet guys run a stock diameter cast iron core, I think Comp calls their premium core a P55 Lobe Lock. They offer gas plasma nitride as an upgrade on the cast iron cores. Yes, the core has its own part number, you'll see it on the card.
