Old 05-22-2016, 10:20 PM   #1
Kevin Panzino
Kevin Panzino's Avatar
Liked 760 Times in 140 Posts
Default Comp Elite Race Series Lifter Axles walking out?
Please disregard title. These are NOT the Elite Race Series, that was an error on my part.
Anyone else had their Comp Sportsman Series lifter axles walk out? There are no 'C' clips on the this series axles, there is a "permantently" peened over ring on each end to keep the axle in. Well on 3 out of 16, the peened ring is gone, and the axles had walked out damaging the lifter bores
Anyone else had this problem?
Old 05-23-2016, 06:49 PM   #2
Denny Steward
Denny Steward's Avatar
Liked 131 Times in 24 Posts
Default Re: Comp Elite Race Series Lifter Axles walking out?
Kevin check these lifters out you won't be sorry.
stewardperformance.com
Denny Steward GT/JA 246
Denny Steward is offline   Reply With Quote
Old 05-24-2016, 09:50 AM   #3
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
have never, would never use comp roller lifters in my motors. Too many reports of their lifters failing over many, many years and for the same reason, ears spreading/axles walking, regardless whether, sportsman, endure-x. IMO and many other racers as well engine builders, Crower Severe Duty are the benchmark. I also don't believe in rebuilding lifters, they are a disposable component.
Old 05-24-2016, 10:14 AM   #4
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
I've tried one set of Comp lifters in 20+ years of racing. This was roughly 5 years ago. I didn't have the problem you are describing, but nonetheless it was a bad choice.
Went back to the trusty Crowers at that time; now running Isky bushed lifters.
S/ST 51
S/C 53
Old 05-24-2016, 10:32 AM   #5
buzzinhalfdozen
Liked 11 Times in 8 Posts
I must be doing something wrong, been running Comp lifters for years...zero failures. Near 400 on the seat and 10,000 RPM. These are Ford and .904 sizes so maybe the bigger size helps.
Joe Buchanan SS/BX 3117
Old 05-24-2016, 12:37 PM   #6
Tom Goldman
Tom Goldman's Avatar
Liked 883 Times in 237 Posts
I have to agree with Joe ,I've been using them for years also with no failures of either their Sportsman or Elite lifters.
I also run 390# on the seat at over 8000 rpm.
Years ago one of Crowers techs told me that most lifter failures not caused by poor maintenance ,ie spring pressure or lash, were due to lateral loading of the bearing caused by the lifter bore not being perpendicular to the cam ,even after being bushed .
Try taking a new lifter ,coat the lobe with Prussian Blue and run the engine thru a few rotations with your normal spring pressure .
You might be surprised by the contact pattern left behind. PS this only works with a new lifter.
That being said if you don't like the current flavor try another , Denny makes a good product .
Old 05-25-2016, 04:06 PM   #7
Kevin Panzino
Thanks for the replies gents!!
Old 05-26-2016, 08:04 AM   #8
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 308 Times in 103 Posts
anytime you are having trouble with lifters,rockers or popping heads off valves,9 out of 10 times you don't have enough spring pressure and lifter doesn't stay on the lobe and beats valvetrain to death.
Mike Taylor 3601
Old 06-02-2016, 05:12 PM   #9
nhramnl
Liked 358 Times in 83 Posts
According to a lifter manufacturer that has a reputation of solid gold, here are the things that can kill a roller lifter:
Inadequate valve spring pressure. Spring simply can't stay in contact with the camshaft and is "tossed". When it lands, the roller wheels that are facing the lobe at that nanosecond get flat-spotted and the irreversible cycle of death has begun.
Also though, too crazy a lobe can cause lifter failure because if the opening ramp is simply too severe, no lifter, regardless of spring pressure, can follow it. In this scenario as well, the valve "toss" occurs and you're headed for trouble. It is for this reason that lobe "extremism" stopped (some years ago) and rocker ratio experimentation began.
Also, this lifter manufacturer said that if neither of the above issues kill your lifters, you should still worry about lifter diameter. Since that advice, I have always opted for at least .904 diameter lifters and have recently stopped using bearings (though I admit that I don't know conclusively that bushings are more durable).
Finally, if you add a bypass fuel pressure regulator to your car, you are almost assured of never having a failure of any kind again, in addition to picking up at least two tenths and four miles per hour.
Old 06-02-2016, 11:51 PM   #10
Adger Smith
Liked 880 Times in 311 Posts
I hope Kevin doesn't mind this follow up. I had a couple of PM's with Kevin about the problem and my strongest suggestion was to check for some sort of alignment problem, esp lifter bore. He blued the cam and checked the roller pattern, no problems there. Kevin talked with a couple of knowledgeable people and figured out it was an alignment problem. Not bad parts, just parts with the wrong off set that created a pushrod alignment problem. Kevin was smart enough to do some cad drawings and figure it out. Side load to the lifters can be death to any companies good parts.
Please keep in mind It is easy to blame parts, but sometimes a little in depth study of the problem will reveal the real issue is not even associated with the failed parts.
Adger Smith (Former SS)
