Old 05-21-2016, 07:53 PM   #1
Coleydog
Liked 53 Times in 38 Posts
Default Leaf springs
Question for Cal-trac use. Can I use the offset hangers and shackles (perch moved in also) in a Cuda stocker?
Old 05-22-2016, 08:47 AM   #2
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
Default Re: Leaf springs
I believe that's a no. From the rulebook, Section 10A:3 "Shock absorbers,springs, or any other stock suspension component may not be moved or altered for any traction-bar installation except those traction bars that are equipped with a new spring perch."
Old 05-22-2016, 05:23 PM   #3
Coleydog
Definition of perch, is that the part that attaches with u-bolts to rear? Just making sure we have the same terminology here. That part is furnished with the kit and the shock does attach to it like the original. Only part offset is the front hanger, using the same stock holes in frame. Probably won't need them anyway just using what I have.
Old 05-22-2016, 08:43 PM   #4
George Mirza
The perch is the part welded to the bottom on the rear end housing that sits on top of the spring. This has to be in the stock location or width. The shock plate is what bolts under the spring. The cal trac bar and shock attach to this.
GEORGE MIRZA STK 1236
George Mirza is offline   Reply With Quote
Old 05-27-2016, 10:50 PM   #5
Rod Greene
Liked 242 Times in 81 Posts
You can't use offset hangers. Plenty of room for the tires on an E body.
Rod Greene Real men shift for them selves. Slowly working on TA Challenger for D,E/S and a 72 Challenger for SS/K, L as if I don't have enough other projects.
Rod Greene is offline   Reply With Quote
Old 05-29-2016, 08:31 AM   #6
Coleydog
69-a-body, not e-body. But I can get them in there with a little " factory" tolerance and not use the offset hangers. Cal-Trac said they don't sell the hangers anymore, just bars and springs. From looking at the early Cameros and Mustangs they must have a lot of "massaging" to get those tires up under them.
Old 05-30-2016, 12:25 PM   #7
Liked 10,852 Times in 2,254 Posts
If you have to weld on spring perches make sure to recheck housing for camber and toe change.
Old 05-30-2016, 12:41 PM   #8
Coleydog
Yes, thanks, I'll weld them first before doing the ends since I made my own alignment jig. I'm going to buy the S60 center with just tubes instead of using the old one I have. I like having adjusters on the carrier bearings.
Old 06-03-2016, 06:28 AM   #9
GTX JOHN
John makes a special narrow leaf spring
for exactly that application and that is what
most guys are using on 67 - 69 Darts out here.
John Irving
741 Stock
741 Super Stock
Old 06-03-2016, 01:01 PM   #10
Michael K
Liked 62 Times in 17 Posts
John - do you know what the width of that leaf is?
Michael K is offline   Reply With Quote
