#31 | |
Liked 71 Times in 38 Posts
Alan, could you describe how the Dwyer gauge works?Is it basically installed like a vacuum gauge? I've never heard of one.Looks like there are several different calibrations.Which is correct to use to measure ring seal as you described? Thanks,Mark |
#32 | |
Liked 1,892 Times in 423 Posts
What you do is connect the gauge to the only outlet where any crankcase pressure can escape from the engine, everything else must be completely sealed. The easiest way is to connect the gauge to a breather with a tube outlet, such as the one used in a crank case evac kit. The gauge must be mounted perfectly vertical. You then make dyno pulls as you normally would. We normally use our vacuum and or evac system for a while to seal the engine up, then after we've got it where we want it and tuned, we make a couple of pulls with the Dwyer gauge on it to make sure it is sealed up.
Alan Roehrich 212A G/S |
#33 |
The one I used was a Fisher-Porter same one Chryser Race Group used was about $300.00 30 years ago. I could hook it up as Alan described and if it was bad enough the weight in tube would bounce just spinning on starter. We would check engine every time we loaded car to come home by hooking up meter and just free rev engine to 6500 rpm if Blowby was over 2 cfm engine would come apart we we got home. Difference on a 740 hp engine on dyno at 6 cfm down was down 60 hp to 1 1/2 cfm. Ted Flack showed us how to use it.
#34 |
OK , I get it now.All I could find online the other day was a round gauge with a bunch of NPT fittings and hoses stickin' out of it.Thanks Guys!
#35 |
Liked 759 Times in 139 Posts
Look at a Dwyer Model# RMC-121. 1 to 10 Cfm range, 10" tall, 1/2" fittings.
#36 |
What I don't know about building engines seems to outspace what I know.
old 1608 stock racer |
#37 |
Liked 22 Times in 14 Posts
#38 |
Liked 166 Times in 71 Posts
Finally got time to do a hot leak down. All cylinders are 5-6% both at tdc and approximately halfway down, at 150 degrees. No access to a dwyer guage here to check that.
Chris Chapman 1969 Chevelle NHRA F-G/SA 1090 |
#39 |
Liked 783 Times in 195 Posts
Great testimony! Lurk on!
#40 | |
Rick Thomason GTOMayhem |
