Old 06-13-2016, 01:04 AM   #1
Camarob859
Liked 8 Times in 3 Posts
Default Launch help!!!
Hi all
Having a problem with my car, just installed a new 8" converter that should flash around 5000, I launch foot to the floor on a 2 step @2500 rolls about 5 feet or so kind of feels like a "buck" car sort of bounces , it's killing my 60' time and what ever it is it doing the same every time combo is 255/350 69 camaro ,ps fuel pressure is 5.5 psi
Camarob859 is offline   Reply With Quote
Old 06-13-2016, 04:13 PM   #2
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Default Re: Launch help!!!
If all you changed was the torque converter, then I would suggest putting your old converter back in and see if your problem goes away .
Old 06-13-2016, 04:55 PM   #3
Camarob859
It's leaving more violently until it starts bucking
Lost about a tenth and the density altitude was 9600 ft
Old 06-13-2016, 06:01 PM   #4
Liked 10,835 Times in 2,252 Posts
fuel spill over?
Old 06-13-2016, 06:15 PM   #5
Camarob859
I'm not positive about spill over no one saw any smoke but not sure if it would smoke as fast as it happens
Old 06-13-2016, 07:54 PM   #6
Ed Wright
Ed Wright's Avatar
I had spill over several years ago when I still ran a carb. No smoke. Larry is likely correct.
Ed Wright 4156 SS/JA
Old 06-13-2016, 08:32 PM   #7
Liked 1,883 Times in 423 Posts
Yes, odds are there is fuel splashing out of the float bowl through the vent, or where the secondary metering rods are.
There is a baffle found on late model carburetors that may help. It is held on by the two screws on the air horn directly behind the choke tower.
Old 06-13-2016, 10:11 PM   #8
Camarob859
Air horn baffle?
Old 06-13-2016, 11:38 PM   #9
henrys57wagon
henrys57wagon's Avatar
http://quadrajetparts.com/used-horn-baffle-p-2428.html
and P 36 on here
http://www.gmcmi.com/wp-content/uplo...ice-Manual.pdf
old 1608 stock racer
henrys57wagon is offline   Reply With Quote
