Liked 7 Times in 5 Posts
can anyone clarify what the blue print sheet is saying under carb for 1970 290hp 360 amc combo becuase i think it should be a autolite 4300 4bl but all the blue print sheet says is (owa-4/auto) i'm pretty positive the /auto is specifying a automatic trans and i've looked through the accepted parts list and didn't see a reference to this. any help would be appreciated
(290 360 10.0 1-4 Ford 0WM-4/SM 0WA-4/AUTO) |
#2 | |
Liked 48 Times in 44 Posts
I have run a lot of Ford 4300's so now & then I obtain an AMC 4300. AFAIK, AMC used the Carter AFB thru 1969, then went to the Autolite 4300. Ford made 2 sizes for the 4300: 1.00" venturi, about 440cfm IIRC this was only used from 1967-69. 1.25" venturi, about 600cfm This was used from 1968-1974. In the AMC numbering, 1st digit is the year, 3rd digit is a=auto or m=manual, and I think last digit means 4bbl. I've had: 3tm4 3ta4 4ta4 I don't know what the 2nd digit "T" vs your "W" means. All the 1.25" venturi Autolite 4300's are the same CFM so I bet any of them would be legal, the only diff is jets & air bleeds etc. |
#3 | |
Liked 101 Times in 52 Posts
0 = 1970 W = engine size M = Manual & A = Automatic 4 = 4V Last edited by Bobby DiDomenico; 06-13-2016 at 02:12 PM. |
i think it is the same 600cfm carb that ford used and that being the case do you guys have a builder you would suggest? i know Deano is the man on quadrajets , so who knows autolites also makes me wonder if there is a quickfuel or replacement option but i haven't seen one.
it would be great if i could use any 600cfm carb i wanted. |
and i guess its a motorcraft not a autolite unless there the same i don't know fords that well.
during the 60's Ford used Autolite as a trade name for a lot of parts. The government for some reason sued Ford and made them sell the spark plug division so Ford started using Motorcraft for their parts and Fram/Allied Signal ended up with Autolite.
Roland |
Liked 2,490 Times in 700 Posts
The best Autolite Carb guy I know is George Thompson "Carburetor Flow
Engineering". I can look up his number if you want. His cars are always near the top of the field out here in the West!
John Irving 741 Stock 741 Super Stock Last edited by GTX JOHN; 06-14-2016 at 06:05 AM. |
Liked 279 Times in 68 Posts
It's not a 780 Holley!
Greg Hill 4171 STK |
Liked 886 Times in 238 Posts
Got that right Greg !
The OWA4 /OWM4 is a Motorcraft 4300. A temperamental sumbitch of a carb that works good with a stick and fair on a 2 step automatic . unpredictable on a foot brake . Most Ford 351 racers run the Holley where it's accepted as a replacement and take the HP ,but a few stick racers run it successfully. Deuce Coupe has the correct info on the sizes and GTX John is right ,Thompson did the carb I ran on my D/S Automatic '70 AMX, Worked as good as you can get from that carb.
