Liked 46 Times in 20 Posts
Is there a formula for weight to horsepower? How much h/p would a 283 have to make to run high 12s in a 3300 lb car?
Liked 1,946 Times in 587 Posts
If you plug those numbers into the Wallace power speed calculator you will need about 320 HP to run 12.80 at that weight.
Mike Pearson 2485 SS |
Liked 372 Times in 130 Posts
Alan Mackin Stock 3777/ SS 3377 P/SA & SS/PA Fox Thunderbird I/PS '95 Mustang GT |
#4 | |
Not sure if that is 304 rear wheel or flywheel hp
304 at the tires will easily run 12.90 in a 3300 lb car.
Ed Wright 4156 SS/JA |
Liked 7 Times in 5 Posts
i'm curious if this is wheel or flywheel hp too, and my other curiosity is if your mph show significantly less hp than e.t. at the same weight does that just mean you have a efficient car?
#7 | |
Liked 48 Times in 44 Posts
It looks like the Wallace link uses NET flywheel power. Then they make assumptions to translate that to rear wheel power which is what move the car. Note they say the formula is just approximate, eg they don't even ask what transmission you have. If MPH is low it can mean a bunch of stuff 1. Running out of fuel on top (common in my old junk) 2. Running out of revs 3. Brick-like aero or headwind (a 5mph headwind will reduce trap speed about 1mph - varies by car of course) 4. Other If you have open headers, not too many belt drives, a big air filter, and cold air coming in, NET horsepower will get really close to GROSS horsepower. Still some losses to get to the rear wheels, no way around that. |
well a amx isn't the most aerodynamic car i can think off and the ets and mph i was using were from a day when we were driving in to a 20 mph head wind but it was good cool air.
#9 | |
Liked 805 Times in 245 Posts
Jim Caughlin SS 6019 |
#10 | |
