Old 06-29-2016, 02:01 PM   #21
joespanova
Liked 13 Times in 11 Posts
Default Re: Oil capacity.......what do you run?
Originally Posted by Bob Mulry View Post
Hi,
I guess nobody wants to tackle the problem of TOO MUCH oil in an incorrectly baffled pan??????????????????
Without the oil controlled it can climb the rear of the oil pan into the spinning crankshaft and foamed (aerated) oil doesn't lubricate.....
Bob
That's right............and at best , all you're going to do is "guesstimate".
Is this baffle effective , how much oil is........ just right?
Old 06-29-2016, 04:24 PM   #22
Kevin Panzino
Kevin Panzino's Avatar
Liked 774 Times in 142 Posts
Hi,
Bob
Yep. Been fascinated by this subject for a while. Would love to be able to "see" inside the pan at rpm. Reher and Morrison ran an engine without a pan on the dyno once and I think they filmed it. Big mess, but great info I'm sure. Would love to see that footage. I think the grump also did this. I do know the grump had a two foot deep pan on his dyno...
Kevin Panzino is online now   Reply With Quote
Old 06-29-2016, 05:51 PM   #23
FED 387
Liked 333 Times in 180 Posts
looks like the inside of a dishwasher oil going everywhere with out baffling or windage trays---3 to 3 1//2 quarts in a comp eliminator car--- engine only runs maybe 30-45 seconds at most anyway----FED 387
Old 06-30-2016, 09:26 AM   #24
randy wilson
Liked 22 Times in 22 Posts
Originally Posted by joespanova View Post
I'm still waiting for a reaction to my comment.......
Anyway........to your point , that definitely helped get me in trouble.....
It got me in trouble. Once. It was fine while running the 1/8th with 5 quarts, but that long 10,000 rpm plus the last 1/8th killed it.
don,t have one
Old 06-30-2016, 10:52 AM   #25
Eman
Liked 133 Times in 76 Posts
I install the dipstick and tube before installing the pan. This lets you ck the actual oil level and where you want full to be, that's if you use a dipstick. Then before installing the pan fill it with water to see how many qts. gets you where you want it. My 7qt. brand name pan would have oil up pretty high if I used 7 qts.
Old 06-30-2016, 11:57 AM   #26
RobbieRacer
RobbieRacer's Avatar
Liked 118 Times in 41 Posts
On my bracket car I put 5 quarts in the 7 quart pan then trimmed the dip stick tube till the stick read full. That way I knew how much was in there.
U/SA
79 Mustang
