Old 07-02-2016, 08:49 PM   #1
dwg4859
Default regulator
I need to buy a better regulator, I have a 278/350 what one should I buy there are a lot on the market. i have a holley
thanks
dwg4859 is offline   Reply With Quote
Old 07-03-2016, 08:49 AM   #2
Woodfin
Liked 288 Times in 109 Posts
Default Re: regulator
With the Super 10 I installed a Quick Fuel regulator. I do not recall the part number but will find it and post later.
Because of class rules, I installed a Quick fuel 585 replacement carb, with 175 fuel pump and QF recommended regulator.
The entire systems has performed as expected with fuel pressure steady at all times.
Some where in the pages of Super 10 build series you can find photos of those components
Old 07-03-2016, 11:42 AM   #3
Alan Nyhus
Liked 799 Times in 236 Posts
thanks
This Quick Fuel unit is a nice replacement for the Holley. It's a non-bypass regulator and works well when you have the bypass in the fuel pump or choose to dead head w/o a bypass.
http://www.quickfueltechnology.com/f...regulator.html
Quick Fuel also makes that style regulator in a bypass model to bypass from the regulator back to the fuel cell.
Lots of other good options out there, as well.
"That'll never work....."
Old 07-03-2016, 01:32 PM   #4
Woodfin
I have the 30-1803 regulator. It operates as expected, pleased with it's performance.
Old 07-03-2016, 03:37 PM   #5
dwg4859
thank u very much
Old 09-06-2016, 07:03 PM   #6
Vinnie78
I just installed a Holley bypass regulator . I know it's a pain to run a return line the same as the supply . Even bigger is recommended . The fuel pump amperage is is less and more consistent and the pump is not dead heading . It also helps with fuel temp .
Vinnie78 is offline   Reply With Quote
