Old 07-12-2016, 08:21 PM   #11
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
Default Re: Tube bars out to front frame on a mopar?
Hi,
The rule had always been..........
Nothing through the firewall......
I don't think that it would change because a cage was the car.....
A K/SA can run a cage if desired......
Just making Stock into Super Stock and Super Stock into Comp....
Bob
Bob Mulry 7516 STK
A & M Motorsports
Old 07-12-2016, 09:51 PM   #12
Tom Goldman
Tom Goldman's Avatar
Liked 883 Times in 237 Posts
Guys that was amended 10/26/15 to section 10A, section 7 page 23 It is legal to run the bars thru the firewall on the inside or over the top of the inner fender .
However section 4 above it says its not , it has been legal since the start of this season. ....You know NHRA never makes mistakes in the rule book !
I double checked this with Dave Ley before I did any.
Old 07-12-2016, 11:22 PM   #13
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
Tom, I looked at the published amendments from mid-2015 and all the publications since then and do not find what you are talking about. In fact, the 10/26/15 amendments are still on the NHRARacer.com site and I do not see that in the document there either.
Old 07-12-2016, 11:36 PM   #14
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Here it is
SECTION 10A: STOCK CARS, BODY:7, FIREWALL (Page 10) (10/26/2015) Alterations prohibited unless expressly permitted in this section. Firewall coverings prohibited. Where heater/air conditioning units have been removed, area must be covered with minimum .024- inch steel or .032-inch aluminum, including rear hood seal/flange, as on GM A-body. Minor firewall modifications permitted to C5 and C6 Corvettes for transmission installation. Roll cage tubing may run across top or side of inner fender well/strut tower and attach to frame horn. See General Regulations 7:4.
Old 07-13-2016, 08:17 AM   #15
Dwight Southerland
Ahhh! I was stopping at the Roll Bar Section; did not read the Firewall Section. I stand corrected.
Old 07-13-2016, 09:39 AM   #16
Wink Re: Tube bars out to front frame on a mopar?
Anyone want to guess why that rule was changed, and who for?
Old 07-13-2016, 09:51 AM   #17
Bob Don
Bob Don's Avatar
Liked 905 Times in 193 Posts
Your Monte Carlo? lol
Bob Don 128 SS
Old 07-13-2016, 10:26 AM   #18
Eric Merryfield
Eric Merryfield's Avatar
Liked 502 Times in 130 Posts
safety for the most part, that image of the duster/demon crash a few years back comes to mind...every bit of cage helps....and lets face it a lot of the race cars are getting a little long in the tooth and can use the additional stiffness, even the lowly Gremlin was slowly twisting itself to the point of concern before its full cage....(pre-this rule, not through firewall)
Just about all of the unibody cars would benefit some more than others. How much it could help ET would be an interesting study.
Eric
Eric Merryfield 1883 STK
Old 07-13-2016, 10:41 AM   #19
Maybe some lead filled ones...
Old 07-13-2016, 12:26 PM   #20
GTOMayhem
Liked 22 Times in 14 Posts
THIS!
Rick Thomason
GTOMayhem
GTOMayhem is offline   Reply With Quote
