Old 08-22-2016, 02:29 AM   #1
PROSTOCKTOM
PROSTOCKTOM's Avatar
Default Ford C4 Transmission Ratio/ Converter for W/SA
Trying to decide if we need the 2.92 first gear set or the 2.75 set for my friend John's W/SA Pinto Wagon.I would guess the 2.92, but thought I would ask and see if anyone that has ran a 2300 Ford would share any information about it.
Also for now looks like it's going to be running a a 9" rear with a 6.20 gear and 26" tires since this is what he already has in stock. Still trying to figure out who to have build a converter for it as well. I am sure it will need a lot with that little 112 HP engine. Might even be interested in a used one if one is floating around.
Any help and guidance would be appreciated.
Thanks Tom
PROSTOCKTOM is offline   Reply With Quote
Old 08-22-2016, 10:48 AM   #2
Bobby Fazio
Bobby Fazio's Avatar
Default Re: Ford C4 Transmission Ratio/ Converter for W/SA
Be careful of the drop between 1st and 2nd gear, it could slow the car down unless you change the 2nd gear ratio a tad. On top of that, where do you get c4 gear sets anymore because I have been looking a while and can't afford $2,000+ for the Pro Trans sets. Doesn't look like Kilgore or Broader make them anymore?
'65 Mustang SS/L & L/SA
Old 08-23-2016, 08:56 AM   #3
Lou Jeffery
I listed a couple sets of low gears for a Ford C4 under parts for sale.
Lou Jeffery is offline   Reply With Quote
