Old 08-22-2016, 01:15 PM   #1
JP Schuster
Default Minimum Weight in Modified Class? - Super Stock
Does the 5% weight break for automatic transmissions apply to the minimum weight posted as well? i.e. if the minimum for SS/TA is 3350 lbs, can you apply the automatic trans 5% so that the actual minimum is 3185 lbs if using an automatic?
Thanks,
JP
JP Schuster is offline   Reply With Quote
Old 08-22-2016, 05:10 PM   #2
Mark Markow
Mark Markow's Avatar
Liked 9 Times in 3 Posts
Default Re: Minimum Weight in Modified Class? - Super Stock
yes 8.5lbs . x cubic inch. x.95 % to get min. weight, or if your engine is small enough to run at 3350. you CAN take another 5% OFF. and be below the 3350 lb. min.
Mark Markow
171 ss/tb
Mark Markow is offline   Reply With Quote
Old 08-23-2016, 07:15 AM   #3
JP Schuster
Thanks Mark.
