Old 08-22-2016, 09:17 PM   #1
barnca2010
barnca2010's Avatar
Default How far under will they go...
Ok boys and girls.. For the 62nd Annual US Nationals.. NHRA has pulled the HP hit that STK and SSTK will get.. So it means that people should hopefully let it rip.. Our little contest is, Guess what the number will be for STK and SSTK. The closest to it wins a custom carb cover from Steve Broadbent at SIDS SHEET METAL. Also in the event of a tie.. We are going to do a coin flip on FB LIVE VIDEO.. So pick heads or tales along with what you think the magic number will be...
Thanks and good luck.
Post your pic on the thread on our FB page.
www.facebook.com/wheelzupradio
Old 08-22-2016, 09:54 PM   #2
Barnstorm
Barnstorm's Avatar
Default Re: How far under will they go...
If the Seville shows up 2.10 under
Old 08-22-2016, 11:34 PM   #3
SStockDart
SStockDart's Avatar
Liked 606 Times in 213 Posts
Without the HP factor....someone will go 2 seconds under......did I just say that??? It will be a lower class car.. (has to be) probably a U/S type car.
Old 08-23-2016, 08:55 AM   #4
Daran Summerton
Daran Summerton's Avatar
Liked 66 Times in 37 Posts
First K/SA in the 10'S !!!!!
72 cutlass
Daran Summerton is offline   Reply With Quote
Old 08-23-2016, 11:05 AM   #5
Bob Bender
Bob Bender's Avatar
Liked 460 Times in 91 Posts
O/SA 11.50 or P/SA 11.70
Bob Bender 144 O/SA
Old 08-26-2016, 02:18 PM   #6
herbjr
Liked 83 Times in 32 Posts
Not happening.
herbjr is offline   Reply With Quote
Old 08-26-2016, 09:53 PM   #7
ALMACK
ALMACK's Avatar
Liked 373 Times in 131 Posts
There was an N/SA that ran in the 11.30's last year at the Indy fall event.
I'd say the same car in P/SA will run 11.80's this year in the heat
P/SA & SS/PA Fox Thunderbird
I/PS '95 Mustang GT
Old 08-26-2016, 10:00 PM   #8
ALMACK
ALMACK's Avatar
Wow
1.66 under in the heat ?
I/PS '95 Mustang GT
Old 08-28-2016, 07:40 PM   #9
Tom P
Liked 239 Times in 94 Posts
I think bump spot would be a better contest (.822 under Stock and .803 under SS)
I'd hate to throw out a guess if there is a new COPO Camaro coming out Tuesday rated at 310hp with an 18 to 1 compression, dual Dominator, inch lift 572. No doubt an already well-tested example would be running 3 seconds under.
Old 08-28-2016, 08:36 PM   #10
Stock, 1.65 under.
