Old 08-26-2016, 08:19 PM   #1
MikeMoller
MikeMoller's Avatar
Liked 254 Times in 78 Posts
Default Trans weight - turbo 350 vs 200 metric
Can anyone tell me the weight difference between the metric 200 and turbo 350. Any difference in converter weight-8 inch?
Mike Moller
NHRA 203 Q-R-T/SA
Old 08-26-2016, 08:38 PM   #2
Liked 5,153 Times in 1,967 Posts
Default Re: Trans weight - turbo 350 vs 200 metric
Mike I can't remember for sure , but I think 20 -25 lighter on the 200.
The converter difference would be negligible .The hub is shorter and smaller diameter, but the pilot has to be extended , and also the mounting lugs , in most cases
Old 08-26-2016, 08:45 PM   #3
Dave Ribeiro
Liked 56 Times in 27 Posts
Wink Re: Trans weight - turbo 350 vs 200 metric
Mike,
I think it was 50-60 lbs. on the tranny, Metric is lighter ... I don't think there's
3-4 lbs. difference in Convertor's ... Hope this help's & hope all is well ..
Good Luck @ Indy & enjoy yourself ... Have Safe Travel's...
Dave Ribeiro 1033 STK
Old 08-26-2016, 09:53 PM   #4
Liked 1,936 Times in 436 Posts
It depends on the TH350. A TH350 with two aluminum drums, lightened planetaries, a 250C sun gear shell, and 250C output shaft is fairly light.
I think Mark is pretty close.
Old 08-27-2016, 08:01 AM   #5
Jim Hanig
Liked 99 Times in 49 Posts
How about a PG and the 200.
Old 08-27-2016, 10:19 AM   #6
Very close to the same, depending on what options they are fitted with.
Old 08-28-2016, 11:08 PM   #7
Greenlight
Liked 81 Times in 23 Posts
OEM weights
http://www.probuildamerican.com/wp-c...ions-gm-th.jpg
Greenlight is offline   Reply With Quote
Old 08-29-2016, 08:01 AM   #8
Lou Jeffery
Assuming we are talking about Stock and Superstock the overall vehicle weight needs to stay the same, lighter transmission must adjust with ballast. The big difference would be any parts of the transmission that rotate. The 350 has a heavy large valvebody, heavy pump assembly and a iron low roller support. These parts just go for the ride and do not rotate. Has anyone compared 200 - 350 internals?
I know this question has been asked before without very clear answers, "How much does a Stocker pick up by replacing a race prepped 350 with a race prepped 200?"
Lou Jeffery is offline   Reply With Quote
Old 08-29-2016, 10:10 AM   #9
pfordamx
Liked 7 Times in 5 Posts
Even though the car has to remain the same weight at least if you took it out of the transmission you could put the weight where you want it, and that may not be much of a advantage but it i'd say it counts for something.
pfordamx is offline   Reply With Quote
Old 08-30-2016, 02:29 PM   #10
Alan Nyhus
Liked 800 Times in 237 Posts
My Powerglide and Metric 200 were within 2 lbs. of each other with similarly lightened internals.
"That'll never work....."
