Old 09-11-2016, 07:22 AM   #11
Lee Valentine
Liked 319 Times in 68 Posts
Default Re: 1st gear ratio ?
I knew someone sharper than me would have some answers.
Lee Valentine 1661 STK
Old 09-11-2016, 11:51 AM   #12
Eman
Liked 133 Times in 76 Posts
I don't know where you are but the weather for us has been slow this year. Comparing log books from last year same dates to this year et's are slower as the weather has been hot and humid.
Old 09-12-2016, 09:21 PM   #13
cameron4link
I'm in Ontario Canada and hot hear also which is prob playing a part ! Thanks everyone for the help!
cameron4link is offline   Reply With Quote
Old 09-13-2016, 10:57 AM   #14
dragracer502
dragracer502's Avatar
Liked 10 Times in 8 Posts
What Motor do you have?
330 hp Vortec head in my car. Powerglide 2.10 low gear, 5.38 rear and a 94 inch circumference rear tire and you should make the 1/4 mile finish line.
F Federico
NHRA J/SA
dragracer502 is offline   Reply With Quote
Old 09-13-2016, 08:41 PM   #15
cameron4link
Yes 330 hp car, i will check tire size i cant remember off hand,i'm not looking to brake records but think car should run 6.85 on a good day ? How fast are these cars going with 385 hp motors ? I am new to this crate motor stuff thanks
Old 09-14-2016, 09:50 AM   #16
dragracer502
Yes, .85 is respectable in the 1/8. But , its all relative, depending on class. 3rd Gens with a 330hp generally run F G or H. In H 6.85 is fast, in F, not as much. How much does the car weigh?
F Federico
NHRA J/SA
Old 10-26-2016, 02:54 PM   #17
cameron4link
Sorry for the delay i felt i should scale car before replying,so 30 inch tall tire and car is 3288 lbs with me in it !!
Old 10-27-2016, 07:52 AM   #18
Chris1529
Liked 70 Times in 29 Posts
Why are you trying to run a power glide with a trans brake? Are you running it in stock?
Car would be much better with a metric 200.
Chris Bowman
The Mountain State Mustang
1984 Mustang GT350
Old 10-27-2016, 01:19 PM   #19
PozQB14
Liked 42 Times in 17 Posts
Im curious as well as to why youre running a transbrake, and if so, why you would inform us. Only if you are just running brackets with it then that's fine. I run the exact same combo and ran previously a glide, but now I have a th350 and the 60' times are much better, putting my metric in this week though with a 2.74 low. Your car is very heavy for what it can be, im at 3077 with me in it running F and I don't have any weight anywhere except for the majority in the drivers seat!! My converter stalls at exactly 5k which took me about 4 different converters to finally get the right one in the car. With a 2.75 low gear, shifting at 6500, and 5.38's my shift light comes on about 100-150 feet before the 1/4 mile finish line.
If you are running it in stock, what class do you plan on running? The 385hp guys are low 6's on average from what I've seen.
PozQB14 is offline   Reply With Quote
Old 10-28-2016, 08:33 AM   #20
cameron4link
The car was being bracket raced when i bought it and that is what i am doing with it also,the car was going 6.85's in good weather but the guy kept trans and convertor which was a glide ,so i now have a reid case and a 5800 stall with 196 first gear,i will check the actual stall this weekend,car has h/cm on window,there is a national open near me that i thought i could run the car in but maybe i can't with the glide ? I would like to go a bit faster that's why i was thinking 385 hp combo and that would still keep the car close to legal for ihra if i decided to sell it some day thanks Guys ! Once again i am new to stock,crate motor stuff i just bracket raced !!
