Old 09-16-2016, 04:37 PM   #1
jrstock
Default Converter Question
I'm seeing odd converter stall speed behavior on our data logger.
Anyone have recommendations on a really sharp converter guy to take a look at our data logger results?
Thanks.
jrstock is offline   Reply With Quote
Old 09-17-2016, 09:36 AM   #2
Ultimate Converter Concepts
Sponsor
Ultimate Converter Concepts's Avatar
Liked 59 Times in 12 Posts
Default Re: Converter Question
Good morning, it could be a few things, and if it is varying in the 60' (erratic flash) it will cause odd behavior there and on the fall back on the shift. You can send me a screen shot of a couple of runs to my email , lenny@ultimateconverter.com, I would be more than happy to try and help.
I have taken all my download software off my computer as I receive a lot of downloads to read, and lately a lot of racers do not use their laptop for data downloads and uploads. They use them for personal use and have a nasty habit of getting infected with viruses that they share with their car (tunes) and others, 3 times in one week was enough for me. Screen shots and conversation work
Lenny Croteau
www.ultimateconverter.com
Phone 704-892-6837
Ultimate Converter Concepts is offline   Reply With Quote
Old 09-19-2016, 09:28 PM   #3
Kevin Panzino
Kevin Panzino's Avatar
Liked 759 Times in 139 Posts
jrstock, check your PM's.
Old 09-23-2016, 10:48 PM   #4
Bobby Fazio
Bobby Fazio's Avatar
Liked 4,379 Times in 502 Posts
Not to hijack the thread but I always thought converter flash rpm and shift drop rpm were normally the same. Is it possible for a working engine and converter combo to flash off the line to 5500 and then drop to roughly 6100 on the gear changes?
'65 Mustang SS/L & L/SA
Old 09-24-2016, 01:25 AM   #5
Adger Smith
Liked 880 Times in 311 Posts
Stator is fixed in position. Pump section of the converter rotates engine speed. Turbine is fixed to the Trans input so it rotates trans input shaft speed.
There can be Fluid pressure differential between the Pump, Stator and Turbine depending on the speeds of the pump and the turbine. It is as simple as the pump side of the converter may be efficient at stall speed on the line (Turbine not moving) and inefficient as the turbine picks up speed with the car moving and the input shaft turning. It can also be the Stator design and the way it directs fluid movement. All your good converter guys know and understand what is happening and build according to what your combination needs. Just another reason you have converters with positive, negative and neutral fin angles. There is way more going on in a converter than just stall speed. Why would a good Comp team spend the money for 3 -5 very similar converters for one engine? To add to the confusion you can buy 2 converters built with identical parts and have the same part numbers, but they will not be identical twins. One will be better looking!
Adger Smith (Former SS)
