Old 10-17-2016, 09:40 AM   #1
Rusty Davenport
Liked 101 Times in 27 Posts
Default Msd6al-2 in the 6900-7200+ range experience
Is it possible for a miss at the finish line in the 7000 rpm plus range to be occurring because the MSD6AL-2 is not "enough" box ??? Everything on this car including the MSD6AL-2 is new except for an MSD distributor which was used very little. I have moved the rpm limiter way out enough that I don't think it is hitting it, but it sure feels like it but to add to the mystery it is worse at times than others. It misses close enough to the finish line to be aggravating. Any comments on the MSD6AL-2 or ideas ???
NHRA AND IHRA STOCK ELIMINATOR 2772
Rusty Davenport is offline   Reply With Quote
Old 10-17-2016, 10:01 AM   #2
Mark Lewis
Liked 208 Times in 45 Posts
Default Re: Msd6al-2 in the 6900-7200+ range experience
Could it possibly be going lean on fuel mixture?
Mark Lewis is offline   Reply With Quote
Old 10-17-2016, 10:07 AM   #3
Brian Fink
Liked 28 Times in 9 Posts
Although I wouldn't rule out the MSD, I would look elsewhere first ; coil or possibly plugs would be suspect .
Brian Fink is offline   Reply With Quote
Old 10-17-2016, 10:09 AM   #4
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
No and put a chip in that is 800 RPM higher than your shift/trap rpm.
Old 10-17-2016, 10:30 AM   #5
terry1
Liked 24 Times in 13 Posts
Smile Re: Msd6al-2 in the 6900-7200+ range experience
Rusty, remember that the MSD stuff draws about 1 Amp for every 1000 RPM's.
If it comes down to the "box", I would check your power supply to it.
Terry K
terry1 is offline   Reply With Quote
Old 10-17-2016, 11:00 AM   #6
Woodfin
Liked 288 Times in 109 Posts
Of course, any system can have a problem, yet the MSD 6AL-2 is a good box and very capable of high RPM without issue.
Some things to consider,
*spark plugs
*spark plug wires
*rotor phasing
*condition of cap & rotor
*fuel pressure
*the above suggestion of raising chip RPM is good or run without a high limit chip.
*in addition, valve float is a possibility
all just food for thought.
And consider that just because "everything is new" well, new can have a problem.
Old 10-20-2016, 01:33 PM   #7
cad
cad's Avatar
Liked 93 Times in 52 Posts
68 Camaro 3300lbs SBC. 7500rpm in the traps.
6AL box, MSD distr.
Mid-season, I had a miss that progressively got worse. Started at the top end, and eventually all the time. Popped like it was on the limiter, so pulled the high side chip. It didnt fix it.
Started watching the fuel pressure, and it was all over from run to run.
Turned out to be a weak fuel pump.
Swapped it out at the track and has run perfect since.
Clark
Old 10-21-2016, 12:38 AM   #8
Everett Vassar
Liked 2 Times in 2 Posts
Too much plug gap can sometimes cause a high gear miss,would normally be a fairly soft miss.
Everett Vassar is offline   Reply With Quote
Old 10-21-2016, 09:41 AM   #9
race watcher
I had the same issue . Same box. Changed the coil wire and fixed it. I might add that was not my first guess.
race watcher is offline   Reply With Quote
Old 10-21-2016, 12:16 PM   #10
Tom Moock
Liked 10 Times in 6 Posts
Check for rust in distributor on magnet pickup, I had that problem once. Tom
Tom Moock 5704 STK
Tom Moock is offline   Reply With Quote
